best compression to turbo
Old Jun 29, 2007 | 08:34 PM
RGSH22ACCORD's Avatar
Default best compression to turbo
what is the best compression to turbo. turbo person from over here said if you turbo a high compression motor you will make more power than a low compression motor runinng the same amount of boost
Old Jun 29, 2007 | 08:53 PM
xbn83's Avatar
Default Re: best compression to turbo (RGSH22ACCORD)
This topic has been covered so many times. https://honda-tech.com/zerosearch
The key is in tuning.
Old Jun 29, 2007 | 09:26 PM
ProjectXaccord's Avatar
9.0-9.5:1 compression is the best. still can run high boost, and still have some power when not in boost. also the motor doesnt detonate with the CR. you can also run about 10:1 CR but a really good tune is required for that.
and what the other guy said yeah its also in the tuning to.
Old Jun 29, 2007 | 11:13 PM
phatsindabuildin's Avatar
the higher the compression, the easier your motor will denotate. which is very bad news...
just dont overdo anything, compression/psi. and yes of course good tuning also helps
Old Jun 30, 2007 | 10:03 AM
dtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGSH22ACCORD &raquo;</TD></TR><TR><TD CLASS="quote">what is the best compression to turbo. turbo person from over here said if you turbo a high compression motor you will make more power than a low compression motor runinng the same amount of boost </TD></TR></TABLE>
I would say 9:1 would be ideal.
Old Jun 30, 2007 | 10:52 AM
streetracer6rpt's Avatar
9to1 all the way
Old Jun 30, 2007 | 04:07 PM
ProjectBB6's Avatar
Default Re: best compression to turbo (streetracer6rpt@aol.com)
8.5:1
Old Jun 30, 2007 | 08:05 PM
PrecisionH23a's Avatar
We typically run 9.0:1 compression on 90% of our turbo builds.
john54321
May 18, 2005 08:25 PM
TehMoonRulz
May 16, 2005 01:15 PM
ej1 pilot
Jun 18, 2004 03:35 PM
s0liDyNe
Jul 19, 2003 10:24 PM
