Help Tuning cams for track racing with my gearing!
Old Jun 29, 2007 | 07:33 PM
psegs80's Avatar
Default Help Tuning cams for track racing with my gearing!
Briefly hear is my setup:JDM b18c-R is putting down 196whp @ just over 8400rpm on a 1100 series mustang dyno. It has been ported,has Toda spec Bs and supertech valvetrain. OEM p73-00 81.25mm pistons, spoon header ported intake manifold and 64mm TB. I also have a civic type r gear box with ats 3-4-5th gears and a spoon 1.5way diff Toda Flywheel and Bully ST3 clutch....I only have a printed graph of my dyno results.
I have herd and read that "You want the peak torque at the start of each upshift and for this peak to continue on for 500-1000rpm after the upshift.
My peak torque is at 6000rpm and it slowly starts to fall at 6700rpm (Cams set 0,0 and head only milled 0.002")
Shifting at 8800 with my ATS gears:
2-3 7000
3-4 7100
4-5 7100
*By playing with cam gear timing, is there anyway for me tomove my peak torque up or to move my peak hp down to help lap times with my gearing
Thanks
Old Jun 29, 2007 | 10:34 PM
JjuuN R's Avatar
Huk...
Old Jun 29, 2007 | 10:55 PM
Big Phat R's Avatar
Default Re: Help Tuning cams for track racing with my gearing! (psegs80)
it's not peak torque you should be aiming to optimize
you should look for maximum area under the torque curve
you might want to play around with the VTEC x-over point a bit - but again - you should aim for maximum area under the torque curve when doing this
otherwise i would get some driving books and learn how to drive better -- "Speed Secrets" is a great book.
that can save you x.x seconds per lap for free
Old Jun 30, 2007 | 01:53 AM
Pompiuses's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psegs80 &raquo;</TD></TR><TR><TD CLASS="quote">I have herd and read that "You want the peak torque at the start of each upshift and for this peak to continue on for 500-1000rpm after the upshift.</TD></TR></TABLE>
Yes that is correct, when accelerating in a straight line that is the most effecient torque curve.
However when racing on a track you often need to use a higher gear through many corners. That means the revs will often drop pretty low when accelerating out of the corner.
So with your gearing and I'd say peak torque around 6000rpm would be good for a track car.
I'd focus on adjusting the cam gears for more torque from 6500-7500rpm, because that's the most likely rev range you will be at when accelerating out of corners. But do so without loosing the midrange you've alredy got. Whether that's possible or not depends on your setup and tuner.
Old Jun 30, 2007 | 06:31 PM
psegs80's Avatar
Default Re: Help Tuning cams for track racing with my gearing! (Pompiuses)
In theory, how would I move the cam gears to attempt this! I'm in Ottawa and there is only 3 tuners. The one I use is very good but mostly does forced induction and doesn't play with cam gear very often...peopleare cheap and don't want to spend on the extra dyno time!
Thanks
Old Jul 1, 2007 | 12:21 PM
psegs80's Avatar
"otherwise i would get some driving books and learn how to drive better -- "Speed Secrets" is a great book.
that can save you x.x seconds per lap for free "
Thanks for the heads up on the book. I understand the driver is the biggest part of the equasion for sure. I've just completed the best racing school in my area a few months back (Trac Racing) and now have my regional race license....trying to put the car together to compete in 2-3 events in the Candadian Castrol Touring Car Champ.
I'm by far a rookie when it comes to seting up my car wether it's Camber angles, Toe angle, playing with my DMS suspension to dial it in or optimizing my power ban..therfore I appreceat all advise or imput!
Thanks
Old Jul 1, 2007 | 09:52 PM
Black R's Avatar
25 Year Member
with a honda, you really want to shift as high as possible.
soo.... post a dyno graph and worry about where the hp lies on the upshift rather than the torque - since your gearing will multiply the torque anyway.
look 3/4 of the way to the bottom:
http://bensebuilt.livejournal.com/
And if you don't believe me, try driving your course timed shifting so you fall to peak tq on your graph. Then do another lap shifting at redline.
hondapowerb16a2
14
May 14, 2009 07:45 PM
RicTRD
Apr 18, 2005 08:55 PM
jdm civic 2000
Dec 25, 2002 09:02 AM
ImportReview
Aug 22, 2002 03:32 PM
HX_Guy
Jun 25, 2001 10:12 PM
