car wont go into gear
Old Jun 29, 2007 | 06:13 PM
hafaadaiteg's Avatar
Default car wont go into gear
i have a 94 ls w/b20 block...my car wont go into gear at all...i can turn it on but it wont engage..but when its off it goes in gear
with the car on with the clutch down and in gear it moves like it wants to take off!!!
has anyone encountered this before?
Old Jun 29, 2007 | 10:14 PM
dc2415's Avatar
Default Re: car wont go into gear (hafaadaiteg)
You might want to check your master cylinder, sounds like the slave cylinder went out. Happened to me a long time ago, and I think that the seal inside the master cylinder had a tear in it? not too sure, but you might want to start there
Old Jun 30, 2007 | 12:10 AM
NightRiderS2K's Avatar
In-N-Out Burger
Its a sign of a clutch going bad,...
Same exact symptoms as mine. Oh and my clutch just got toasted today Good thing I have a backup ACT clutch I will be able to install tommorow
Old Jun 30, 2007 | 10:12 AM
dimwitrj's Avatar
Sounds like the problem I had with my teg when I bought it. A spring broke off of the clutch.
Old Jun 30, 2007 | 01:08 PM
integra686's Avatar
Default Re: (dimwitrj)
the misinfo on this site is awesome.
don't waste money, its your slave cylinder.
Old Jun 30, 2007 | 03:55 PM
luv2boost's Avatar
Default Re: (integra686)
Check your master and slave clutch cylinders first. If they are both good it could be a spring that came out of your clutch or I had a pressure plate bolt come loose and get wedged so I couldnt get it to go into gear.
Old Jun 30, 2007 | 07:39 PM
In-N-Out Burger
Default Re: (luv2boost)
Either the slave cylinder then or clutch itself.
Old Jun 30, 2007 | 07:44 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra686 &raquo;</TD></TR><TR><TD CLASS="quote">the misinfo on this site is awesome.
don't waste money, its your slave cylinder. </TD></TR></TABLE>
There was no misinformation. The master and slave cylinders are easy to diagnose. Don't rule out a faulty clutch, as I have seen failures that meet the OPs symptoms.
Old Jul 1, 2007 | 08:47 AM
dc2415's Avatar
Default Re: (Dogginator)
Either way, let us know how it goes, good luck
Old Jul 2, 2007 | 08:33 PM
thanks guys ill let you know how it goes
pkdog167
Sep 19, 2008 04:24 PM
lo0nY
Feb 26, 2006 03:58 PM
scrEaMO Kyle
Nov 3, 2005 11:49 AM
Luchini
Oct 16, 2005 11:15 AM
