rusted bolts...help?
Old Jun 29, 2007 | 04:25 PM
jdmjunkie8's Avatar
Default rusted bolts...help?
Im tryin to put my new skunk2 exhaust on and the bolts connecting to the cat are rusted on there bad, does anyone have a way to get them off?
Old Jun 29, 2007 | 04:34 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: rusted bolts...help? (jdmjunkie8)
WD-40 or anytype of good screw lose and let it soak, then try again, if that doesn't put a pipe on the end of the wrench and have someone start jumping on it. They are either going to come off or break and you will just have to go get new ones, if they are rusted you should probably get some new ones anyway...
Old Jun 29, 2007 | 05:59 PM
mrdeadman's Avatar
They let me pick
Default Re: rusted bolts...help? (St Jimmy)
PB Blaster owns all rusty bolts.
Old Jun 29, 2007 | 06:06 PM
Madness's Avatar
Default Re: rusted bolts...help? (mrdeadman)
I agree. PB Blaster is the best penetrating oil I've ever used. Blows WD40 out of the water.
But most likely those exhaust bolts are going to snap anyway. The exhaust heat and exposure to the elements tends to really trash them.
Old Jun 29, 2007 | 07:59 PM
Bignel00's Avatar
pb blaster ,if not the tourch solves all the problems
Old Jun 30, 2007 | 05:55 AM
Dogginator's Avatar
Daisy... Daisy...
I would just cut the old ones with an angle grinder or saws all. Be careful of the ends as the spring is applying force to them. You can clamp vice grips onto the ends to slow their departure when the bolt is cut.
jkalex05
Aug 8, 2009 02:09 PM
5lugSlug
Mar 18, 2006 03:20 PM
Kal
Nov 17, 2005 02:52 PM
A Blue Lude
Jul 28, 2005 05:47 AM
au-gsr
Nov 13, 2002 04:37 PM
