sway bars, GS vs. Type R
Old Jun 29, 2007 | 03:43 PM
Liu Kang's Avatar
Default sway bars, GS vs. Type R
what is the difference in the size of the mm and has anyone switched over from GS/LS to type R? can you really feel the difference? is it worth the extra money?
Old Jun 29, 2007 | 03:48 PM
numbnuts22715's Avatar
I swapped from my gsr to a type r and i noticed a HUGE different.
I'm not sure about the specs of the ls/gs sway bars, but I know the GSR is atleast as good, or better, so if it made a huge different to me, it will to you as well.
I hope that helps at least a little.
Old Jun 29, 2007 | 05:26 PM
Difussion3's Avatar
If your talking about the rear sway bar, I believe the gs/rs is 13mm, gsr is 14mm, and the type r is 22mm. I also know that the front sway bar for the gsr is 26mm.
Old Jun 29, 2007 | 05:30 PM
Liu Kang's Avatar
Default Re: (Difussion3)
so I have a gs, is there anything I need to install type R sway bars?
Old Jun 29, 2007 | 05:34 PM
alexisthemovie's Avatar
rear subframe reinforcement kit. there are dozens of threads covering this, please search the archives.
and yes, this is probably the best bang for buck mod for your car.
Old Jun 29, 2007 | 05:38 PM
Difussion3's Avatar
Yea theres a few reenforcement kits out there. If you dont use one you will tear your subframe. Theres an ASR, beaks, and bsq that I know of.
Old Jul 2, 2007 | 06:31 AM
Liu Kang's Avatar
so if I put in just the type R rear sway bar, I will end up tearing out the subframe? I got a hold of the sway bar aleardy, so does anyone sell just the subframe? What about the front? Is anything else required to get that installed? Is there a difference between the JDM and USDM?
Old Jul 2, 2007 | 11:36 AM
myfirstdc2's Avatar
Default Re: (Liu Kang)
usdm 22mm jdm 23mm for the rear. u have to have a subframe kit or it won't fit without modification of stock sub frame. and stock ls/gs/rs is only 12mm. u will feel a huge difference in handling if u take u car on hard turns. as for the front jdm type r is 25mm and u will need gsr/type r front end links. the ls/gs/rs end links will not work. if i am forgettign something ill come back a post again. hope this helps u out
Old Jul 2, 2007 | 07:09 PM
94rs-turbo's Avatar
rs,gs,ls- fronts 22mm rears 12mm
GSR- fronts 24mm rear 14
USDM ITR fronts 24mm rear 22
JDM ITR 96-97 fronts 24mm rear 22
JDM ITR 98+ fronts 25mm rear 23mm
honestly dont worry about the jdm 25mm front though
Old Jul 2, 2007 | 07:24 PM
mr nut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liu Kang &raquo;</TD></TR><TR><TD CLASS="quote">so if I put in just the type R rear sway bar, I will end up tearing out the subframe? I got a hold of the sway bar aleardy, so does anyone sell just the subframe? What about the front? Is anything else required to get that installed? Is there a difference between the JDM and USDM? </TD></TR></TABLE>
http://www.beaksproducts.com
meric0786
Apr 22, 2009 09:38 PM
blazin415
Suspension & Brakes
16
Oct 2, 2007 04:32 PM
Crackerballer
Apr 27, 2006 07:48 AM
Blazineyez
Apr 12, 2006 03:38 PM
civicmatt
Oct 8, 2002 09:29 PM
