Itr owners, have a second?
Old Jun 29, 2007 | 03:03 PM
digital sol's Avatar
Default Itr owners, have a second? Hosing question
Just wanted to post this here sense im sure id get a faster reponse as im in a bit of a hurry. Basically im just wondering where this line is supose to go to and/or if its already connected properly. I removed the pvc system and evap cannister. Im running my catch can from the block with no drainback "will empty when it gets full"
I know the very far bottom left hose on the intake manifold goes to the thermastat housing. But what about the nipple/hose right next to it on its right? Theres a smaller outlet hose to the right of the coolant hose and im not quite sure where it gets run to.
Ive got it running to the lower line on the throttle body. And 1 hose from the iacv to the block and another from the iacv to the other closest port on the lower section of the throttle body "facing firewall". Then the two nipples/ports on the top of the intake manifold "one facing firewall, one facing toward front of car" are capped off with vacum plugs.
some shitty pics..
Old Jun 29, 2007 | 03:06 PM
migs's Avatar
Pics are horrible.
Let me ask this, what year block, head, and intake manifold are you running?
Did you powder coat your intake manifold black?
Old Jun 29, 2007 | 03:08 PM
Default Re: (migs)
usdm itr intake manifold, 00 jdm block, head
yes its been ported and powdercoated etc'. My original intake manifold was a jdm itr, this intake manifold is the us version, one difference i noticed is that the vacum line for the fpr is on the front instead of the rear like on my old manifold other than that they looked pretty identical
throttle body is also different than my old jdm itr throttle body, just differnt hose port locations
Old Jun 29, 2007 | 04:03 PM
Default Re: (digital sol)
im just gonna run a hose from there to the iacv and bypass the throttle body'
the small line is indeed coolant for the tb/iacv system etc
Old Jun 29, 2007 | 09:17 PM
neo_'s Avatar
So you powder coated my old IM? Any pics, I am curious.
Old Jun 30, 2007 | 02:04 AM
Default Re: (neo_)
ill get pics tomarrow, been a 20 hour day working on the car and still runs like ****...towing it to the tuner in 3 hours..wish me luck...i sure as hell need it
MugenTGZ
May 22, 2013 01:57 AM
g_steelo99
Aug 5, 2012 07:23 PM
81CB900C
11
Jul 11, 2007 04:19 PM
blinger
20
Jan 29, 2007 03:23 PM
EF8IGHT
Nov 8, 2005 07:53 AM
