Spark fuel but wont start?
Old Jun 29, 2007 | 12:15 PM
Stray's Avatar
Default Spark fuel but wont start?
i had some aftermarket cam gears on my b16 got it starting but it was backfiring alot so i put ls cam gears on and timing on and not it wont even spark starter fluid wont get it to start. what could be the probably?
Old Jul 4, 2007 | 09:16 PM
jdmcars.com's Avatar
Default Re: Spark fuel but wont start? (Stray)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stray &raquo;</TD></TR><TR><TD CLASS="quote">not it wont even spark starter fluid wont get it to start. what could be the probably?</TD></TR></TABLE>
Well, if it will not spark -that is problem #1. Starter fluid will not do anything if there is not spark.
Put your start fluid down, and look into why it will not spark.
Check Dizzy, replace if needed.
Check timing
Old Jul 5, 2007 | 12:33 AM
HOODLOVER's Avatar
well your basically putting fuel thru the intake right?and if it doesnt even try to start check spark,and keep going backwards from there till you find the problem,three things the engine needs to run correctly is airfuel,spark,and compression,someone correct me if im wrong
teetstyshon
Feb 12, 2013 10:27 PM
sLoWrAcEr
Jan 16, 2010 08:38 PM
oakpwr
Jan 20, 2007 06:00 PM
nylshatch
Nov 28, 2005 06:29 PM
t3to4e
Jan 7, 2004 05:00 AM
