Acura Legend Calipers... 2 piston? can it be bolted to ITR? is it better than a ITR caliper?
I heard the Acura legend calipers are identical to the nsx caliper.. they are two piston??? can you bolt it to a ITR suspension? and is it worth it? Are they better calipers than the ITR calipers???
this will be going on a EK
naw the nsx calipers are aluminum and they actually have the NSX logo on them other wise yea they are the saem
the legend and nsx calipers have pros and cons... double vs. single piston, costs, material makeup, low cost vs. high cost, sleeper vs. bling factor, etc., etc.... get the legend calipers... more bang for the buck!
need redrilled 4x100 rotors for your brake upgrade?
https://honda-tech.com/zerothread?id=2030926
Wrong, and no.
The Legend calipers are similar to ITR calipers. The Legend GS calipers are a two piston caliper than can be attached to an ITR bracket with the addition of a 5mm shim. The NSX caliper is not aluminum. It is a two piston caliper with heat vanes and NSX letters. The pistons are a little smaller compared to the Legend GS caliper. It too could use a 5mm shim when bolting to an ITR caliper bracket. They are a bit heavier and on road use, there is no noticable difference (I have ran both).
If you need these and/or their milled brackets, PM me.
shawnhayes
42
Feb 16, 2009 12:03 PM
TypeSH
Mar 19, 2002 09:16 AM
