disc swap
anyone swaped teg rear disc? is it as simple as i heard?
wut i need from teg, just the rear mono beam? more parts?
would like to have rear disc then upgrade pads all-a-round?
know of some good pads?
did i mention for 1st gen crx......
[Modified by 86CRXSi, 5:02 AM 6/7/2002]
I have a 90Si and upgraded to rear discs and I used all the parts from a '92 Teg. The whole control arm with all the parts attached. I read about this swap in an old issue of "Grassroots Motorsports" . You would need all the parts on both sides of a 87-89 Teg including the e-brake cables and brake lines. Just swap it out. It's a direct bolt on process. You wont have to dissamble except to change to new rotors. Some good pads would be "Hawk Blues." Good Luck!
[Modified by clean90Si, 1:51 PM 6/7/2002]
[Modified by clean90Si, 6:02 AM 6/7/2002]
If you have access to the whole rear suspension meaning the axle beam with the trailing arms on it then just get that. It makes the swap a lot easier then having to take the trailing arms off and the panhard bar. I had teg disks on my '87 Si hatch and its a lot easier to just unbolt all the old stuff and bolt up the integra axle beam and trailing arms.
And on the brake lines ,you will want to get integra ones theyre a little long but you can zip tie 'em to the trailing arms. I got my brake lines from BAP for around $35 each i think.
mrtoastyjr
31
Jun 22, 2004 04:33 PM
