DRAG SLICKS?
Old Jun 29, 2007 | 07:11 AM
tapboyzlilj's Avatar
Default DRAG SLICKS?
ALRIGHT PUSHING 185HP AT WHEEL, FIRST TIME EVER RACING WITH SLICKS
20-8-14 MT'S DIDNT KNOW HOW TO RACE SLICKS, RAN A 14.4 WITH SLICKS GOT MAD TOOK IT OFF AN RAN 14.2 ON STOCK TIRE'S NO TRACTION 1-2...
IT WAS MY FIRST TIME WITH SLICKS IT FELT LIKE I DIDN'T KNOW IF MY TIRE'S WERE SPINNING OR MY CLUTCH SLIPPING IT FELT LIKE ME MOTOR WAS JUSS REVING BUT MY TIRE'S NOT SPINNING... HELP?
WHAT RPM TO LAUNCH/WHAT PSI TO SET TIRE'S.
Old Jun 29, 2007 | 08:43 AM
h22crxpwr's Avatar
Default Re: DRAG SLICKS? (tapboyzlilj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tapboyzlilj &raquo;</TD></TR><TR><TD CLASS="quote">ALRIGHT PUSHING 185HP AT WHEEL, FIRST TIME EVER RACING WITH SLICKS
WHAT RPM TO LAUNCH/WHAT PSI TO SET TIRE'S.</TD></TR></TABLE>
those slicks are really small.... and post up your timeslip or at least the details so we can see your 60', and what psi did you run those slicks at? i'd say go with the 22x8x13 inch slicks because those are WAY small worked great on my single cam . and you will be fine. but post up what psi you ran the slicks at and your timeslip if possible.
Old Jun 29, 2007 | 09:13 AM
SpeedSceneScott's Avatar
Default Re: DRAG SLICKS? (h22crxpwr)
Wow, and I thought my 22's were small.
Also, are they new or used? Did you get all the water off them after the burnout?
Are they a different diameter than your stockers? (If so, you have a different final drive number)
You need to do more than 1 run to get some real data.
Old Jun 29, 2007 | 09:14 AM
Default Re: DRAG SLICKS? (SpeedSceneScott)
Oh, you shoulda got M and H slicks!!!!!!!!!!!!!!!
Old Jun 29, 2007 | 11:48 AM
ALRIGHT SORRY GUYS RAN THE SLICKS AT 12 PSI - LAUNCHING AT 5500, AN WAS ONLY GETTING 2.2 60 FOOT/ TRAP MPH 94, I RAN IT LIKE THIS 4 TIMES AN ALL TIMES WHERE IDENTICAL... AT THE END OF THE TRACK IT SEEMS LIKE MY TOP END WAS SLUG-GESS, LIKE I DIDNT HAVE ENOUGH HP OR SOMETHING
RAN 14.2@96MPH 2.2-60FOOT STOCK KUMHO TIRE'S@22PSI...
I'M THINKING ABOUT PUTTING MORE AIR IN THE SLICKS LIKE ABOUT 19-20 PSI...
AN TAKING OFF AT 6500-6800 RPM
Old Jun 29, 2007 | 11:54 AM
ALL IMPORT's Avatar
u need less air go down 2 about 8psi in the slicks. & bring the rpm up a little more.
do a burn out till u get some good smoke. 2nd gear burn out keep the revs up.
Old Jun 29, 2007 | 06:59 PM
Mista Bone's Avatar
D Tranny Guru
20x18x14 MT at 12 psi on a 14x6 rim, do a burn out in 2nd gear, launch at 7000+ rpms.
Z6 on 85 shot, about 180-190 whp, 1.816 foot, 13.09 ET.
Also is you car lowered and the camber excessive? More than 1.5-2 degrees negative camber will effect the MT's.
I'm on my 4th set
Old Jul 2, 2007 | 09:31 PM
Default Re: (Mista Bone)
alright going to try the slicks again this time i'm going to smoke the hell out the tires an lauch at 6800-7000 ffuucckk it... 13's hopefully...
Old Jul 3, 2007 | 12:10 AM
s4yama's Avatar
Default Re: DRAG SLICKS? (ALL IMPORT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL IMPORT &raquo;</TD></TR><TR><TD CLASS="quote">u need less air go down 2 about 8psi in the slicks. & bring the rpm up a little more.
do a burn out till u get some good smoke. 2nd gear burn out keep the revs up.</TD></TR></TABLE>
I agree, lower the pressure and smoke the hell out of those tires, you'll be happy with the results. Just keep messing with the tires and forget about the street tires.
Old Jul 3, 2007 | 12:24 AM
Mista Bone's Avatar
D Tranny Guru
20x8x14's below 12 psi will spin on the rims, so unless you have beadlocks, no need to go belowe 12 psi.
Old Jul 3, 2007 | 06:25 AM
fmfkid250's Avatar
REV LIMITER IS YOUR BEST FRIEND, USE IT!
Old Jul 3, 2007 | 06:55 AM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tapboyzlilj &raquo;</TD></TR><TR><TD CLASS="quote">ALRIGHT SORRY GUYS RAN THE SLICKS AT 12 PSI - LAUNCHING AT 5500, AN WAS ONLY GETTING 2.2 60 FOOT/ TRAP MPH 94, I RAN IT LIKE THIS 4 TIMES AN ALL TIMES WHERE IDENTICAL... AT THE END OF THE TRACK IT SEEMS LIKE MY TOP END WAS SLUG-GESS, LIKE I DIDNT HAVE ENOUGH HP OR SOMETHING
AN TAKING OFF AT 6500-6800 RPM</TD></TR></TABLE>
those slicks are way too small for your setup. go with the 22x8x13. i wouldnt put more air in those slicks unless you just want to spin more??? seriously your best bet would be to go with some 22's. you can easily find them used for a decent price. and if you are on a budget go with the Lenso wheels.
Old Jul 3, 2007 | 12:00 PM
Mista Bone's Avatar
D Tranny Guru
13.09 @ 103, stock Z6 on 75 shot. 1.8 60', they 20x8x14's were perfect.
Free gearing advantage......
Old Jul 3, 2007 | 12:19 PM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">13.09 @ 103, stock Z6 on 75 shot. 1.8 60', they 20x8x14's were perfect.
Free gearing advantage......</TD></TR></TABLE>
like i said in my first post "worked great on my single cam" and a 1.8 60' doesn't sound "perfect" to me i'd be disappointed if i hit 1.8's......... since when i had a b-series (like the OP has) i used the 22's and was getting 1.6 60's, 1.6 60's sound a lot better to me than 1.8 60's but thats just my opinion ......
Soda Popinski
Nov 21, 2005 07:24 AM
ALLMOTA_EF
Jan 29, 2004 04:37 PM
ALLMOTOR18
Jul 22, 2003 10:38 PM
Waachback
May 6, 2003 01:40 AM
Kermit EK
Aug 22, 2002 06:35 AM
