Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Adding in an OEM Honda Navi unit to a non-navi SI
Old Jun 29, 2007 | 01:17 AM
elohel's Avatar
Default Adding in an OEM Honda Navi unit to a non-navi SI
I'm in the position to buy a brand new OEM Navi unit for $600.
I'm most likely going to buy it.. just wondering what I would need to do to get this into my car? I figure I have to buy the double din dash peice and the wiring harness, what all else do I need to do?
Also.. would I be missing some of the features that you get when the navi is factory installed? Just wondering if some of the things that a factory navi unit has couldn't be wired in and whatnot.
Old Jun 29, 2007 | 01:58 AM
gus738's Avatar
Default Re: Adding in an OEM Honda Navi unit to a non-navi SI (elohel)
dynamicautosound best deal you'll get and much better then crappy oem set tell him raul/gustavo sent you he'll hook you up good
Old Jun 29, 2007 | 06:38 AM
Type X's Avatar
complete dash harness
microphone
gps antenna
voice control switches
steering harness
wiring to mic
steering wheel trims
possibly a navi DVD
then wiring it in.
mine is 100% completely functional
Old Jun 30, 2007 | 10:40 AM
gus738's Avatar
Default Re: Adding in an OEM Honda Navi unit to a non-navi SI (Type X)
oem navi vs aftermarket 99% of the people would perfer aftermarket cuz it plays dvds and stock dont and you can do a bypass to watch dvds on the go and you would need like x said dash kit (oem or scosche or metra ebay) wire harness oem ant adaptor and if you have the oem preimuim sound you need a reverse wire harness for the bypass of factory amp ( crutchfiled)
Old Jun 30, 2007 | 10:42 AM
Type X's Avatar
Default Re: Adding in an OEM Honda Navi unit to a non-navi SI (gus738)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gus738 &raquo;</TD></TR><TR><TD CLASS="quote">oem navi vs aftermarket 99% of the people would perfer aftermarket cuz it plays dvds and stock dont and you can do a bypass to watch dvds on the go and you would need like x said dash kit (oem or scosche or metra ebay) wire harness oem ant adaptor and if you have the oem preimuim sound you need a reverse wire harness for the bypass of factory amp ( crutchfiled)</TD></TR></TABLE>
I had an Eclipse unit that was over 2500 dollars in my element.
OEM &gt; aftermarket ... trust me.
Old Jun 30, 2007 | 10:45 AM
gus738's Avatar
meaning that oem pawns aftermarket? you cant compare a new oem say against a old or cheap aftermarket , it should be like new vs a new modern in dash you know?
Old Jun 30, 2007 | 11:25 AM
Kidnkorner's Avatar
since you scored the OEM for $600 rock it. I have my eye on Kenwoods set up, mostly because they use Garmins infrastructure. But if I had the opportunity to score OEM for $600 I'd get that. Currently I rock a Garmin StreetPilot 7500, but this was purchased for work related use. Its the biggest portable GPS unit on the market with a 7.5" LCD screen. It's really cool, but all the wires coming from the 3 wires coming from the unit doesn't provide a clean look and hopefully I can get something in dash soon.
Old Jun 30, 2007 | 03:07 PM
elohel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">complete dash harness
microphone
gps antenna
steering harness
wiring to mic
possibly a navi DVD
then wiring it in.
mine is 100% completely functional</TD></TR></TABLE>
Thanks for the info guys.
Mind telling me how much you spent on all that stuff x?
Old Jun 30, 2007 | 03:24 PM
burnout8488's Avatar
microphone
gps antenna
steering harness
wiring to mic
possibly a navi DVD
That would be enough to turn me away. Yikes!
Old Jun 30, 2007 | 03:26 PM
gus738's Avatar
Default Re: Adding in an OEM Honda Navi unit to a non-navi SI (burnout8488)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burnout8488 &raquo;</TD></TR><TR><TD CLASS="quote">
That would be enough to turn me away. Yikes!</TD></TR></TABLE>
x2 same here thats why im saying aftermarket is all you need plus its a bonus of having ability to play dvds and more stuff oem cant touch on top of that you can get new indash navi/dvd for that price but even if the op were to go oem route he would need to spent more with several things like harness dash kit and all required acc....
Old Jun 30, 2007 | 04:19 PM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gus738 &raquo;</TD></TR><TR><TD CLASS="quote">meaning that oem pawns aftermarket? you cant compare a new oem say against a old or cheap aftermarket , it should be like new vs a new modern in dash you know?</TD></TR></TABLE>
i had the highest model eclipse AVN in 04 and went from that to an 05 tsx so its not like it was a 10yr old difference it was months.
Old Jun 30, 2007 | 04:20 PM
Type X's Avatar
x2 same here thats why im saying aftermarket is all you need plus its a bonus of having ability to play dvds and more stuff oem cant touch on top of that you can get new indash navi/dvd for that price but even if the op were to go oem route he would need to spent more with several things like harness dash kit and all required acc....</TD></TR></TABLE>
how many trips do you take to watch dvd's ?
can you watch while driving?
is it 1999 are you hooking up a PS3 or something in the car
all the extra stuff = not needed.
Old Jul 21, 2007 | 10:02 PM
iceboi714's Avatar
do you have any pictures of ur set up Type X....not sure how you took stock system out...
thanks
Old Jul 21, 2007 | 10:37 PM
iceboi714's Avatar
Default Re: Adding in an OEM Honda Navi unit to a non-navi SI (iceboi714)
also....say i wanted to add a aftermarket navi to a non-navi SI....what exactly would i need.....the double din dash obviously the navi sysyte.....but what else?
Old Jul 22, 2007 | 08:42 PM
killyourscene's Avatar
hey ive been wondering this for awhile. maybe theres someone here that works at the dealership that would know this.
Can you go to honda and have them install the navi after you bought your car and add the cost onto your car payment?? that would be sweet if you could do that!
Old Jul 23, 2007 | 03:45 AM
20strong's Avatar
Hey X thanks for the info I was curious about that myself. Sounds like a spendy but worthwile venture.
iceboi714 Read the whole thread there is a list a couple posts up.
killyourscene I am pretty sure that you can not add anything to the car and put it in your finacing unless it is done before purchasing (or while of course)
Old Jul 23, 2007 | 09:46 AM
rbf351's Avatar
it takes me about an 2-3 hours to install an OEM Navi system in a non Navi car.
if interested, and live in NY or NJ email me, and i can give you pricing
Raymoe420
Mar 13, 2012 08:18 AM
RattyTuned
Feb 9, 2012 11:07 AM
Dan Fizzle
Jan 21, 2009 08:18 PM
stickershop.ca
20
Jul 25, 2006 04:14 AM
