Obd 2 Clips with obd1 injector's info'
Old Jun 29, 2007 | 12:49 AM
digital sol's Avatar
Default Obd 2 Clips with obd1 injector's info'
Long story short im currently running stock jdm itr injectors "obd2". How-ever ill be upgrading to tuner toys 440cc injectors "obd1". I was simply wondering if removing the blue plug inside the obd2 clips which are currently installed would allow me to use the original clips with the new injectors. Just wanted more info on the subject. Ill need to drive my car to the dyno on my current injectors and swap them when i get there, if i can just pull the blue pieces outta the clips than it should be a quick little change and i can just swap them when i get there.
Its either that or simply cut the old clips off, solder the new ones on with a bit of extra wiring "18" guage. And just have it towed to the dyno.
thaiphob
Aug 4, 2017 10:40 AM
Turbo_y8
Jan 20, 2006 09:19 PM
aesthetics82
Apr 2, 2003 05:39 AM
