Yet another warning about Skunk2 camber kit
What else is there???
I got mine form King, and they sent Skunk.
Listen folks.. they are fine if you do some precautionary work to them.
1. I used a dremel and scored the surface where the washers go.
2. Loctite the threads.
3. I also scored the washers too, but you can buy serrated lock washers.
4. TIGHTEN ALL 4 BOLTS.. TIGHT!!!
Great idea.. I think I will also ditch the allen bolts all together and use regular ones..
Maybe a bit longer too... just for that extra bite.
Thanks.
Thanks.
Yeh, I forgot to mention the length of the bolts would need to be increased. Thanks. It's late. You could also safety wire the bolt heads.
Reid - who has the federal gov't to thank for learning how to properly safety wire those bolts on the hydraulic actuators...
electronb16si
Feb 14, 2005 05:20 PM
