Grinding noise coming from driver's side rear wheel
Old Jun 28, 2007 | 09:32 PM
dtec's Avatar
Default Grinding noise coming from driver's side rear wheel
I just put on some 17's on my 4th gen Prelude. There's a grinding noise coming from my driver's side rear wheel. None of the other wheels make this grinding noise. Does anybody know what the wheel can be grinding against? The wheel size is 17x7...
Old Jun 28, 2007 | 09:45 PM
vteclude07's Avatar
Default Re: Grinding noise coming from driver's side rear wheel (dtec)
when ur going down the street at 30mph. get out, run after it and check.
but anyways check around the tire first, might be some plastic
Old Jul 2, 2007 | 10:10 PM
mexicovi1la's Avatar
You might want to check your brake pads to make sure their not rubbin or too low. I had the same problem on my drivers right front wheel i changed pads cause i needed them anyways and solved the problem. I dun think you have to change your pads but i would check it, maybe even take it off put it back on and see if that works. they maybe unbalanced too
Old Jul 3, 2007 | 02:41 AM
killingtwobirds's Avatar
shocks
Modified by killingtwobirds at 4:14 AM 7/6/2007
Old Jul 3, 2007 | 02:43 AM
SnlpeR's Avatar
^^^ best answer EVAR!
b20acura
Jun 28, 2011 12:20 PM
avio
Apr 7, 2010 07:52 PM
pin3appel
May 26, 2009 07:51 AM
carbonlaced
Jun 27, 2006 10:02 AM
01blackgsr
Apr 17, 2005 12:46 PM
