OEM LSD in GSR tranny?
Old Jun 6, 2002 | 07:20 PM
InfamousRS's Avatar
Default OEM LSD in GSR tranny?
Would the OEM LSD from a 1st gen b16 tranny or ITR tranny fit into a GSR tanny? Is it somthing even worth while?
Old Jun 6, 2002 | 08:40 PM
Type R 1090's Avatar
New User
Default Re: OEM LSD in GSR tranny? (InfamousRS)
Didn't the JDM Integra SiR (GSR here) have an LSD?
Old Jun 6, 2002 | 09:37 PM
MK Ultra's Avatar
I'm almost positive that the B16 differential will not fit due to the B16's ring gear being smaller than the B18C1's (although the ratios are the same).
The stock ITR LSD will fit just fine.
Old Jun 6, 2002 | 11:54 PM
Honda F1's Avatar
Default Re: OEM LSD in GSR tranny? (MK Ultra)
Yep Mk is correct. The ITR LSD will slide right in a B18c1 tranny. If your buying a brand new LSD though I would highly recommend a Quaife unit. Basically the same price as OEM but much better performance.
Old Jun 7, 2002 | 01:26 AM
Eeepers's Avatar
New User
Default Re: OEM LSD in GSR tranny? (Mr. JDM)
a quaife is basically the same price as a oem lsd? reallY?
Sure, if you get it from a stealership. But it can be had for very cheap (used one)
Old Jun 7, 2002 | 04:08 AM
GreenR's Avatar
Default Re: OEM LSD in GSR tranny? (Eeepers)
Yes, I have ITR LSD in my GSR tranny and its like night and day.
Old Jun 7, 2002 | 06:24 AM
Darkteg's Avatar
New User
Default Re: OEM LSD in GSR tranny? (J-Red)
what about fitting the oem itr lsd on a b16a2 tranny? is it possible?!
Old Jun 7, 2002 | 08:59 AM
MK Ultra's Avatar
Default Re: OEM LSD in GSR tranny? (Darkteg)
Perhaps.
You would have to change the ring gear and countershaft to B18C parts, but I'm not quite sure if the differential itself will fit in the B16 tranny case.
Old Jun 7, 2002 | 09:10 AM
Honda F1's Avatar
"a quaife is basically the same price as a oem lsd? reallY?"
A Quaife lists for about 850, and ITR LSD is around 800ish I believe.
Old Jun 7, 2002 | 10:28 AM
InfamousRS's Avatar
Default Re: OEM LSD in GSR tranny? (HONDAF1)
If I do this, I will find a used one. I read that used ones run from $300 to $500. I think that is a good price range for LSD. If I were to have to buy it brand new, I wouldn't bother, I would just get the quaife unit.
Is there any new parts I will need/should buy, like bearings and that sort before installing the OEM unit?
Old Jun 7, 2002 | 10:40 AM
ee-gsr's Avatar
Default Re: OEM LSD in GSR tranny? (Type R 1090)
I believe it was an option on the SiR.
Old Jun 7, 2002 | 11:36 AM
Fuminsho's Avatar
Default Re: OEM LSD in GSR tranny? (ee-gsr)
How about just mating a ITR or CTR trani to a B16A motor? Do any of you know if it will fit?
Old Jun 7, 2002 | 02:15 PM
InfamousRS's Avatar
Default Re: OEM LSD in GSR tranny? (Fuminsho)
Yes, I believe that will work.
DoWork17
Jul 9, 2009 07:32 PM
NinjaTurtles
Mar 24, 2005 03:21 PM
InfamousRS
Jun 6, 2002 09:01 PM
jArceo
Apr 23, 2002 08:33 AM
