Assembling EG dash. Need ID of this wire ASAP!
Old Jun 28, 2007 | 05:18 PM
sead21c's Avatar
Default EDIT: Assembling EG dash. (Done) Now Wipers wont turn off.
I remember unplugging this black wire, but don't remember where it goes now. It is a black wire with two sets of white marks on the cable. It has a plastic cap to it. Seems like a ground. Attached are pics of the cable, it's tip and the main dash harness it comes from. Any help would b appreciated.
EDIT: Finished the Dash but now the Wipers will not turn off even when on the off position. Did a search but couldn't narrow down the problem.
Modified by sead21c at 3:51 AM 6/29/2007
Modified by sead21c at 3:53 AM 6/29/2007
Old Jun 28, 2007 | 05:20 PM
VTEC IS UR BEST FRIEND's Avatar
Default Re: Assembling EG dash. Need ID of this wire ASAP! (sead21c)
believe that wire goes somewhere in the clock/guage cluster area as a ground wire that clip in to the dash frame
Old Jun 28, 2007 | 05:21 PM
sead21c's Avatar
Default Re: Assembling EG dash. Need ID of this wire ASAP! (VTEC IS UR BEST FRIEND)
gona check that out now.
Old Jun 28, 2007 | 05:24 PM
akunamatta's Avatar
* B A N N E D *
never seen that before, looks aftermarket.
Old Jun 28, 2007 | 05:25 PM
sead21c's Avatar
Default Re: (akunamatta)
i think i found it. i believe that it is a metal tab sticking out the frame. I inserted it and it fit right in. Hopefully that's it.
And no it's not aftermarket.
Old Jun 28, 2007 | 05:28 PM
shorsh's Avatar
never seen that either, must be for something stupid
Old Jun 28, 2007 | 05:32 PM
sead21c's Avatar
Default Re: (sead21c)
So I looked unde th dash located on the metal frames/bracket and found a tab sticking out. It looks familiar and the plug fits. What do you think?
Old Jun 28, 2007 | 05:33 PM
sead21c's Avatar
Default Re: (shorsh)
shorsh: dont you have parts to get low-balled for? Help me finish the rest of the dash you dipshit.
Old Jun 28, 2007 | 05:48 PM
poppypizza's Avatar
its a ground goes behind where the cluster sits kinda hard to see
Old Jun 28, 2007 | 06:27 PM
mike1114's Avatar
Default Re: (poppypizza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poppypizza &raquo;</TD></TR><TR><TD CLASS="quote">its a ground goes behind where the cluster sits kinda hard to see</TD></TR></TABLE>
The man is correct, goes to the right of the gauge cluster, almost behind a little.
There is also another one for the cigarette lighter.
Old Jun 28, 2007 | 06:34 PM
shorsh's Avatar
hulsey
Jan 19, 2013 05:42 AM
ivicr
Mar 25, 2010 03:14 PM
ATX45
Apr 30, 2006 09:14 PM
shivic
Aug 2, 2005 06:03 PM
sodacan33
Jun 21, 2004 05:51 PM
