My Car Shakes When pressing on gas
Old Jun 28, 2007 | 05:14 PM
jdm12345's Avatar
Default My Car Shakes When pressing on gas
All of a sudden my car keeps shaking whenever i gas it but doesnt shake when i dont gas it. what can be wrong with my car? My thought was a mount, can this be right ?
Modified by jdm12345 at 10:57 PM 6/29/2007
Old Jun 28, 2007 | 05:17 PM
97Ej6mike's Avatar
Motor mounts, suspension, clutch? Few things it could be. We need your car's year, motor, and modifications you have done. Is it a soft shake, a violent shake? We need more info.
Old Jun 28, 2007 | 05:43 PM
spoonracer84eg's Avatar
Default Re: (97Ej6mike)
The timing could be off... the plugs or wires could be going bad or could have oil on them causing them to foul out... ignition coil could be going bad. It could be almost anything. Do you have a vtec motor? If so does the vtec engage normally? When my ignition coil was going out the car would bog when vtec would engage. Just some ideas. Good luck.
Old Jun 28, 2007 | 05:57 PM
AK_20_EM1's Avatar
yo home slice check your axles. probably banged one up!
Old Jun 28, 2007 | 06:00 PM
97Ej6mike's Avatar
Default Re: (AK_20_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK_20_EM1 &raquo;</TD></TR><TR><TD CLASS="quote"> yo home slice check your axles. probably banged one up! </TD></TR></TABLE>
It would be a constant vibration then, that woud be related to the vehicles speed, this is apparently only when the gas is on. Sounds motor related.
Old Jun 28, 2007 | 07:31 PM
jdm12345's Avatar
i just hope its nothing too major .. the vibrating isnt too bad...i just hope its a low budget repair..if its mounts thats nothing..all that i can only think about right now is it wuld b the mount ..hope to see more ideas soon...
EGlove23
21
Jan 14, 2013 02:13 PM
The Phil
Jun 28, 2005 12:48 AM
geminis2k
Nov 10, 2003 01:14 PM
Honda Sport
Oct 28, 2003 01:31 PM
V-Grip! Teknic73
Jul 8, 2003 01:05 PM
