PCV valve not connected
Old Jun 28, 2007 | 04:13 PM
jorge59la's Avatar
Default PCV valve not connected
i just realized that my PCV valve is not connected to the IM. its just sitting there with nothing comming out of it.
What does that mean?
Is this bad?
Should i replace the valve and connect it to the IM?
thanks...
Modified by jorge59la at 7:42 PM 6/28/2007
Old Jun 28, 2007 | 07:56 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: PCV valve not connected (jorge59la)
The PCV valve routes unburned fumes from the crank case back to the IM so it can be burned and catalyzed. It also serves to relieve pressure inside your crank case.
Since its venting into the atmosphere, its relieving pressure.....but it's also polluting the air more than it should be. Reconnect it if you like to breath.
Old Jun 28, 2007 | 09:08 PM
Kyoto now's Avatar
Default Re: PCV valve not connected (B serious)
All the PCV valve does is vent unburned fuel vapors back to the combustion chamber, along with a little oil residue. The inside of your IM will look like a dirty chimney after time, though.
Old Jun 28, 2007 | 09:29 PM
jorge59la's Avatar
Default Re: PCV valve not connected (Battle Version)
i guess thats when the catch can comes in!
Old Jul 3, 2007 | 09:05 PM
MidwestCivic's Avatar
it also sucks unburnt fumes from your oil so it doesnt get contaminated, you WANT that connected
kb58
Mar 24, 2011 10:38 AM
justint
Dec 27, 2006 04:33 PM
petrv
Aug 26, 2005 02:26 PM
dr juice164
Jul 11, 2004 10:04 AM
1.8T_EG
Nov 19, 2002 03:05 AM
