hamp oil filters
Old Jun 28, 2007 | 03:53 PM
frankie11's Avatar
Default hamp oil filters
Has any one used hamp synergy oil filters on there type-r before? I searched, didnt find anything on these
Old Jun 28, 2007 | 04:42 PM
cltitus's Avatar
Default Re: hamp oil filters (frankie11)
jdmland.com
they work jsut fine for me i have like i bought like 100 something when i was in iraq so far i got 97 left
Old Jun 28, 2007 | 04:56 PM
R you serious's Avatar
Default Re: hamp oil filters (cltitus)
yeah, theyre like 3 for 900Y, super cheap and thats all ive ever used.
its an oil filter though, who cares if your changing your oil often enough.
Old Jun 28, 2007 | 05:00 PM
slofu's Avatar
Honda
After
Market
Performance
iirc, they're made by Toyo Roki, who makes the better OEM Honda filters (Fram makes the lesser ones). i have them. color aside, they're identical to the OEM Honda S2K filters.
Old Jun 28, 2007 | 05:01 PM
frankie11's Avatar
Default Re: hamp oil filters (R you serious)
i had seen them on jdmland.com, they claim there great for v-tech engines because they regulate oil pressure better and also raise it by 5 psi, I was planning on buying some because they are cheap and seam like they are better then most. anyone else have any thoughts on these?
Old Jun 28, 2007 | 05:03 PM
itrSteez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankie11 &raquo;</TD></TR><TR><TD CLASS="quote">i had seen them on jdmland.com, they claim there great for v-tech engines because they regulate oil pressure better and also raise it by 5 psi, I was planning on buying some because they are cheap and seam like they are better then most. anyone else have any thoughts on these?</TD></TR></TABLE>
How many more years am I going to have to see this followed by ******** like myself calling the mistake out?
Old Jun 28, 2007 | 05:07 PM
frankie11's Avatar
Default Re: hamp oil filters (itrSteez)
and what is the mistake?
Old Jun 28, 2007 | 05:08 PM
cltitus's Avatar
v-tech is a phone
vtec is honda
Old Jun 28, 2007 | 05:10 PM
frankie11's Avatar
Default Re: (cltitus)
ok, so is it really worth correcting? you know what i am saying.
Old Jun 28, 2007 | 05:18 PM
cltitus's Avatar
Type-R Forum = ****
Old Jun 28, 2007 | 05:22 PM
frankie11's Avatar
type-r forum= many people who sit home looking for errors on honda-tech.com
Old Jun 28, 2007 | 06:49 PM
nautica_t's Avatar
^its not looking for error.
but when you read you can see the error.
and as for the filter no idea. if there is solid proof of 5psi gain on the hamp filter.
Old Jun 28, 2007 | 07:06 PM
sp00nek9's Avatar
Default Re: (nautica_t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankie11 &raquo;</TD></TR><TR><TD CLASS="quote">type-r forum= many people who sit home looking for errors on honda-tech.com</TD></TR></TABLE>
you came in this forum to ask type R owners their opinions and them bash them?
Old Jun 28, 2007 | 07:10 PM
JjuuN R's Avatar
Default Re: (sp00nek9)
Never tried hooking one up to a phone before... the antenna might work?
Old Jun 28, 2007 | 07:17 PM
neo_'s Avatar
Default Re: (frankie11)
itrSteez's Avatar
Any other section on H-T would have called you out just as fast, if you ask me you got off easy.
Old Jun 28, 2007 | 07:25 PM
neo_'s Avatar
Default Re: (itrSteez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itrSteez &raquo;</TD></TR><TR><TD CLASS="quote">
if you ask me you got off easy.</TD></TR></TABLE>
I don't know, I kinda heard a Meow in the background.
Old Jun 28, 2007 | 07:27 PM
cltitus's Avatar
Default Re: (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">
I don't know, I kinda heard a Meow in the background.</TD></TR></TABLE>
i dont think the car wants to play with this one. its not to retarded just rude
Old Jun 28, 2007 | 07:55 PM
Jon D's Avatar
GTFO
Get The Frank Out
Honestly dood.... its a waste of your time to try and e-fight us. Big deal, you mispelled V-attack. If i ran in the corner to hide everytime i got flammed when i first joined i would be nowhere to be found.
Wanna hang out and get to know others? Just go with the flow, even if that means taking some heat at one point or another.
Haven't seen you post too much around here, so welcome. HAMP filters are an excellent choice to answer your question. Honda S2K filters are just as good if you don't have access to a HAMP supply.
Old Jun 28, 2007 | 09:14 PM
slofu's Avatar
if you're using a filter to raise oil pressure, you're raising/measuring pressure on the wrong side of the system; you're only making the pump work harder.
i run the largest OEM filter possible (S2K) for the lowest pressure drop.
consider that the oem filters have a bypass valve that opens in case the filter is clogged; makes sense since unfiltered oil is better than none. if you run a larger filter with the same filtration media (as a smaller version), you'll be able to filter your oil more often (with less restriction), since the valve will remain closed.
keep in mind that in any fluid system velocity and volume have to be balanced. stick your thumb over the end of a running garden hose and think about it.
honda likely went to smaller filter because it saves them $, and they can get away with it now that roller valvetrain allows for thinner oil to be used (and it helps them meet EPA standards).
Eee Kay Nine
Dec 12, 2008 01:19 PM
Built B16A
Dec 10, 2004 02:31 AM
PrecisionH23a
Nov 17, 2003 02:23 PM
xkhalil333x
Sep 28, 2003 01:35 PM
avs
Jul 24, 2002 08:00 PM
