i got really big problem with my honda civic lx 98.need help
here is the problem.
sometimes when i try to start my car i can't start it,i gotta try to start like 10 times ,may be more or less.the ignition works fine,because engine starts then it turns off.
and when i'm driving the car sometimes(rarely) the engine turns off and that's big problem.then it takes me more then 1minute to start it again.
the car does all of this when is hot weather outside,i mean in high temperature.night time and in cool weather car works just fine without any problems i mentioned above.
mechanic told me its fuel pump,so i changed it but still same sh*t.right now i don't know what to do u know.also i changed fuel filter and air filter.
i just want to know if somebody here had the same problem and what cause that problem.
here it is.i changed yesterday main relay but guess what? nothing.same problem.i really don't know what to do.
stick to one thread please https://honda-tech.com/zerothread/2024535
no need to clutter an already cluttered forum
Check your injectors, replace your sparkplugs, change your oil, clean out your TPS sensor, raise your idle slightly, replace your distributor if you have to. DO you have an Check engine lights?
kikacha
Jun 28, 2007 03:14 PM
kikacha
Jun 25, 2007 01:43 PM
