ITR cams in b16..again
Old Jun 28, 2007 | 01:41 PM
SiRkid's Avatar
Default ITR cams in b16..again
LOL, im curious if ANYONE has seen or heard of anyone floating a valve or doing any damage from ITR cams into a stock b16 head and running the itr 8400-8500 rpm redline?
i sure havent. People go on and on about it could happen but ive never seen it. Has anyone else?
I know years ago doug from hondata revved his stock b16 to 9200 all the time and was fine. I used to rev my car to 9000 rpm when it was turbo (in 1st and 2nd gear). All was fine. Even now i dip into 8500 rpm range(Stock cams) in 1st gear sometimes and its been fine. Car has over 100k miles on it.
I want to do this swap but am too cheap/lazy to throw in the diff springs and LMA's.
Im just wondering if anyone has actually seen someone hurt something from doing this.
thanks
Old Jun 29, 2007 | 08:26 PM
DraginTeg93's Avatar
Default Re: ITR cams in b16..again (SiRkid)
wondering the same
Old Jun 29, 2007 | 08:30 PM
Jizzmaster Zero's Avatar
(banned)
Get a D series you fool!
Old Jun 29, 2007 | 10:09 PM
SiRkid's Avatar
Default Re: (Jizzmaster Zero)
Ya d series... wheres the hammer emoticon when you need it?!
Old Jun 29, 2007 | 10:16 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (SiRkid)
You won't have a problem, just don't rev it like a type-r because you have "hype-r" cams.
Nice setup IMO.
Old Jun 29, 2007 | 10:19 PM
raphael's Avatar
get a d16y8 because its better than a b16 or a b18b
Old Jun 29, 2007 | 10:26 PM
turbociviccoupe's Avatar
Default Re: (raphael)
get a k series.
no really though you shouldnt have a problem unless you abuse it by reving higher than you should. ir you want a to rev like a type r buy a type r.
or you can buy springs and retainers. then your rod bolts might give out so you'd have to replace it with arp....aww...just build a motor and you can rev your heart out
Old Jun 30, 2007 | 02:15 AM
poppypizza's Avatar
i know a kid that revved to 9200 alot,, few months later spun 3 rods bearings
93egSLEEPER
Feb 3, 2010 02:31 PM
ej1252
35
Jan 23, 2010 04:59 PM
jadugartir
Apr 11, 2006 02:02 PM
B18C GSR CIVIC
17
Jun 16, 2005 11:50 AM
cr00klyn718
Mar 17, 2002 02:39 PM
