96 Accord with ABS, bleeding?
Old Jun 28, 2007 | 11:12 AM
bonh's Avatar
Default 96 Accord with ABS, bleeding?
I'm going to replace my Brake Master Cylinder tonight and I know I have to bleed my brakes when I'm done. Do I have to do anything special with my ABS system?
I read this: https://honda-tech.com/zerothread?id=1729184
and theres a procedure for bleeding ABS.
But someone also says its two seperate systems so you don't have to expletive with the ABS.
So should I just replace my MC and bleed my brakes as normal and leave the ABS system alone? or bleed the ABS?
Old Jun 28, 2007 | 12:08 PM
The-Kid's Avatar
Default Re: 96 Accord with ABS, bleeding? (bonh)
hey thats my post =D. Anyways since you're not doing anything with the ABS line, I do not think you have to do anything. Bleed it as a normal car without ABS.
Old Jun 28, 2007 | 12:15 PM
TOP END MS's Avatar
ABS and non-ABS are the same method. Please use a manual ANYTIME you work on your car. Forums and general knowledge are NOT enough for a quality job.
eagle458
Feb 3, 2014 10:24 PM
The-Kid
Aug 24, 2006 09:19 AM
jonzel
Aug 18, 2005 04:47 PM
joeseph
May 23, 2003 10:13 AM
