Which headgasket to use? H22A1 vs H22A4
Old Jun 28, 2007 | 10:27 AM
syntax.'s Avatar
Default Which headgasket to use? H22A1 vs H22A4
Considering a h22a1 block with my h22a4 head. Which headgasket would be appropriate? Honda part numbers are 12251-P13-004 for the h22a1 and 12251-P5M-004 for the h22a4. Are they identical?
TIA
Old Jun 28, 2007 | 10:31 AM
Mr.60trim's Avatar
From: What Business is it of yours where Im from Friendo
Default Re: Which headgasket to use? H22A1 vs H22A4 (syntax.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syntax. &raquo;</TD></TR><TR><TD CLASS="quote">Considering a h22a1 block with my h22a4 head. Which headgasket would be appropriate? Honda part numbers are 12251-P13-004 for the h22a1 and 12251-P5M-004 for the h22a4. Are they identical?
TIA </TD></TR></TABLE>
I would go with the gasket made for the h22a4 head
Old Jun 28, 2007 | 10:39 AM
NirVTEC's Avatar
Default Re: Which headgasket to use? H22A1 vs H22A4 (Mr.60trim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.60trim &raquo;</TD></TR><TR><TD CLASS="quote">
I would go with the gasket made for the h22a4 head</TD></TR></TABLE>
So you would go with a gasket meant for an open deck block on a closed deck block?
BAD INFO!
Honda owner in Japan?!?!?! I am crushed......
Use the headgasket meant for the block you are using.......
Old Jun 28, 2007 | 10:59 AM
prelittlelude's Avatar
i would sugest the a1 gasket as well. coolant port between the a1 head and a4 head are almost identical, open or closed makes the choice.
Old Jun 28, 2007 | 01:24 PM
Mr.60trim's Avatar
Default Re: Which headgasket to use? H22A1 vs H22A4 (:=:NirVTEC:=:)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by :=:NirVTEC:=: &raquo;</TD></TR><TR><TD CLASS="quote">
BAD INFO!
Use the headgasket meant for the block you are using.......</TD></TR></TABLE>
****...I totally forgot about the open vs closed deck issue there .
Good catch
Old Jun 28, 2007 | 01:55 PM
Rosko's Avatar
Old Jun 29, 2007 | 08:36 AM
NirVTEC's Avatar
Good catch </TD></TR></TABLE>
Its all good. I just know the heads are the same in every way........
for Honda owner in Japan! I am jealous.
civicmulisha
13
Oct 20, 2008 07:45 PM
Jdmb16sir2
Oct 26, 2007 12:23 PM
VVV
Jul 30, 2007 03:37 PM
greasemonkee
Oct 13, 2005 10:57 AM
evilone
Dec 22, 2004 02:37 AM
