My car won't start
Old Jun 28, 2007 | 08:39 AM
julianaa's Avatar
Default My car won't start
Well to start off, I have a GSR in an EG. Well I had unplugged 2 of my spark plug wires that connect to the distributor the night before. I disconnected wire 3 and 4, and this morning before I went to work, I forgot to reconnect them and I tried to start the car. It started and died immediately. I did this twice and them remember, o snap I left those wires unplugged. So I went back and plugged the wires back in and now the car won't start at all. The fuel pump primes, the main relay clicks, the car tries to crank, but it just won't start.
Could me trying to start the car with those wires out have messed anything up?
Old Jun 28, 2007 | 08:46 AM
stratedrm's Avatar
Default Re: My car won't start (julianaa)
one idea that popped into my head is that the cylinders are flooded with fuel.. because there was no spark to ignite them... once the wires were connected, the plugs were wet with fuel, and couldnt create the spark anymore.
um.. you can either pull the plugs and dry them off with a napkin or something.. or replace them..
Old Jun 28, 2007 | 08:53 AM
julianaa's Avatar
Default Re: My car won't start (stratedrm)
I was just reading the same thing on flooding haha. I'm a go give that a shot and pray that it works
Old Jun 28, 2007 | 08:55 AM
fmrprojects's Avatar
disconnect the plug on the driver side shock tower. its the dead plug. that will kill your fuel pump and just prime the engine to burn off all the excess fuel. then connect it and see if it starts
Old Jun 28, 2007 | 09:52 AM
julianaa's Avatar
Default Re: My car won't start (fmrprojects)
Nope still wouldn't start. I took out the plugs, cleaned them, dropped them back in, disconnect the plugs by the shock tower, opened the gas cap to release pressure, nothing....any other ideas?
The plugs were really black, super black. Should I try some new plugs?
Old Jun 28, 2007 | 09:55 AM
Shake and Bake's Avatar
yea its the crankshaft
Old Jun 28, 2007 | 09:56 AM
julianaa's Avatar
Default Re: (Shake and Bake)
How can you tell?
Old Jun 28, 2007 | 10:37 AM
julianaa's Avatar
Default Re: (julianaa)
Could the main relay be ruled out since the fuel pump primes and it clicks whenever the CEL goes on when you turn the key?
Old Jun 28, 2007 | 11:31 AM
julianaa's Avatar
Gonna change the spark plugs tonight and hopefully my neighbor will let me borrow his distributor to see if that will help anything
Any other ideas?
Old Jun 28, 2007 | 02:02 PM
julianaa's Avatar
Anymore ideas or thoughts?
Old Jun 28, 2007 | 02:13 PM
stratedrm's Avatar
check fuses..?
Old Jun 28, 2007 | 04:55 PM
julianaa's Avatar
Default Re: (stratedrm)
Well it started raining down here and I don't have a garage so I didn't get to work anymore on it. I did check the fuses and they all appeared to be in working shape. I bought the shell off a friend and I remember him saying about the car always blowing a certain fuse, can't remember which one, I guess I better call him and ask him which one. But the ones I checked under the hood all appeared good, I pulled them out and none looked like they were blown
Old Jun 28, 2007 | 06:35 PM
mcclure's Avatar
did u check the firing order?
Old Jun 28, 2007 | 07:19 PM
HaiSpeedRacer's Avatar
Default Re: (mcclure)
did you check to see if you still have spark? I'm thinking your coil went bad...I'd replace the spark plugs first then see if you can borrow your friends dizzy for further testing.
Old Jun 28, 2007 | 08:31 PM
blkSi's Avatar
Default Re: (HaiSpeedRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcclure &raquo;</TD></TR><TR><TD CLASS="quote">did u check the firing order?</TD></TR></TABLE>
yah did you plug them back in in the right order?
Old Jun 28, 2007 | 08:40 PM
julianaa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HaiSpeedRacer &raquo;</TD></TR><TR><TD CLASS="quote">did you check to see if you still have spark? I'm thinking your coil went bad...I'd replace the spark plugs first then see if you can borrow your friends dizzy for further testing.</TD></TR></TABLE>
I couldn't check to see if I had spark b/c I was alone and couldn't get someone to crank the car while I held the spark plug to a bolt or something. I tried to lay the spark plug inside the spark plug wire on a bolt and crank the car myself and see if I could see something, but it didn't work haha. I couldn't see from where I was at.
I was gonna borrow my neighbors dizzy but it started pouring here really bad and I don't have a garage to put the car in So i'm gonna have to wait til about Sunday to try out his dizzy, since I work at AT&T and we're working crazy hours for the release of the Iphone.
I checked the firing order and it's correct. Firing order is: (Top:3-4)(Bottom: 1-2) And 4-3-2-1 correct?
Modified by julianaa at 9:58 PM 6/28/2007
Old Jun 28, 2007 | 10:04 PM
EGfosho's Avatar
OG Tech
ya thats right. Its 4-3-2-1. Dizzy might be bad. take the cap off and check and see if that little thing that spins burnt out or not.
Old Jun 29, 2007 | 06:10 AM
HECTIC's Avatar
yo julian i think i might have an extra cap laying around..
will the distributor cap from an LS work for the GSR...
Old Jul 2, 2007 | 09:43 AM
julianaa's Avatar
Default Re: (HECTIC)
Well I was finally able to test for spark, and unfortunately there was NO spark Still haven't been able to test out my neighbors distributor though. Could it be the ignitor?
Old Jul 2, 2007 | 11:14 AM
julianaa's Avatar
Well I pulled off the distributor today and the it's not rotating with ease. I can feel "clicks" in between each spin. Gonna try out my neighbors distributor just to make sure it's that, then probably just buy a whole new distributor from DK
Old Jul 2, 2007 | 11:44 AM
tortis's Avatar
when i turned my engine over with the wires off, i fried my coil.
lilmisshonda
Jul 2, 2008 09:40 PM
Tad
Sep 5, 2007 09:51 PM
sik96teg
Mar 11, 2006 10:50 AM
dumpeDc2
Dec 30, 2004 09:25 PM
