ls/vtec running on non vtec ecu
Old Jun 28, 2007 | 07:06 AM
crispchris's Avatar
Default ls/vtec running on non vtec ecu
my issue is i have a 2000 integra ls/vtec running having to run on the ls ecu, the car runs but it sounds like a loud truck, is it possible to chip the obd2 ecu or would i have to get a standalone to make the car run smooth. the car is throwing a cel but i believe that is because it's using a vtec engine wire harness and because the ecu was not meant to work with a vtec head, any other opinions? flame all you want just as long as help is given i'll think of it as constructive criticism.
Old Jun 28, 2007 | 07:37 AM
crispchris's Avatar
Default Re: ls/vtec running on non vtec ecu (crispchris)
ok kinda cancel the running part but it should just be the throttle is not staying open enough at idle
Old Jun 28, 2007 | 09:00 AM
4g hatch's Avatar
if u have high compression pistons i think that ecu would fry your motor after a while. if the ecu is set up for hondata,chrome or whatever u can run what ever base map u want just have to activate vtec. to me obd-2 is to sucks *** anyway i would go obd-1. if your gonna run obd-2 i would get a vtec ecu and disable the knock sensor then you'll be good
Dave Brabant
Jun 28, 2018 01:17 PM
94-integra-ls
Mar 23, 2008 04:26 PM
crispchris
Jun 29, 2007 12:33 PM
Dc2 Joe
May 23, 2007 04:35 PM
Dc2 Joe
May 23, 2007 01:03 PM
