HELP WITH CRX B16 ECU WIRING...MISSING PIN.....WHAT TO DO???
Hey guys, I am done installing my b16 in my rex, I ran my extra wires to the new ecu and noticed there is a pin missing to where i need to run a wire. The v-tech selnoid wire runs to clip"A". There is no pin in there whatsoever, What should i do? Do they sell these pins somewhere? Is there somewhere i can take one from so i can run the v-tec to the ecu?? Its the last wire and i seem to hit this minor snag.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx »</TD></TR><TR><TD CLASS="quote">Yeah i did look on this forum and i seen people selling others pins. Never seen an actual process on what to do. I want to do it the right way so i though i would ask </TD></TR></TABLE>
This seriously doesn't help?
Are you using a pre made harness or did you make one? If you made one yourself did you use the proper pins which will plug right into the harness plugs? I'm sure you can get your hands on a pin SOMEWHERE...go to a junkyard and cut up another harness or something. I don't entirely know how i've helped you by telling you go to the junkyard and take out a pin...or go to radioshack or something and get a pin....this should be nothing less then common sense...
Well thats why i asked, Cause i am not sure. I did all of the wiring already and i didn't ask for a diagram, thats common sense if you can read. I was asking about the actual pin that goes into the ecu. On the chassis side of the harness on the crx, The A8 pin does not exist. Does radio shack sell the pin thats fits in the ecu clip? And will it plug into the ecu without any problem? Its a simple question and the smartass comments are not needed!! If it bothers you so much don't post in this thread, thats common sense
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx »</TD></TR><TR><TD CLASS="quote">Well thats why i asked, Cause i am not sure. I did all of the wiring already and i didn't ask for a diagram, thats common sense if you can read. I was asking about the actual pin that goes into the ecu. On the chassis side of the harness on the crx, The A8 pin does not exist. Does radio shack sell the pin thats fits in the ecu clip? And will it plug into the ecu without any problem? Its a simple question and the smartass comments are not needed!! If it bothers you so much don't post in this thread, thats common sense</TD></TR></TABLE>
I'm being awfully helpful if anything! All you needed was a PIN!....and like i replied back to your PM....: Do you not have a radio shack nearby? or even a junkyard? Its useless posts and queries like yours is what pollutes this board with utter unneeded nonsense. If you seriously need to post a query about a single freaking pin then your mom must still spoon feed you and your *** must still need some thorough wiping by someone else. Simple as that...let it end here:
Your question was in cliffs:
Q: "I need to acquire another harness pin since there wasn't one at A8"
A: Get up....go to radio shack and find one...if you don't wanna spend the 4 cents it MIGHT cost...then get to a junk yard with a pair of wire cutters....find practically any honda with the same pin's...cut the harness..put it in your pocket...THERE!
SIMPLE AS THAT! i know..i know...crazy right?
Thanks TREBLE for not being such an *** like pr3d was. I will take a look in radio shack and see what i can find
Modified by alscrx at 3:10 PM 6/28/2007
