repost! . . crx power problem!
something seems to drain my battery like hell!...thought it was my alternator so i tested and it pass..so for the heck of it i just got a new one and installed it..and also purchased a new battery...same thing still have..it drain my battery and it slowly dies down..after i recharge my battery it works good for about a day and a half or so then it dies down again..not sure what is the problem..if you have a clue please let me know...
you're shorting out somewhere...and seems to be a really small short...enough to slowly drain the battery....try installing a kill switch which terminates the connection of the battery to the car and see if that helps.
Its basically the same as disconnecting your battery every time you turn off the car...do this to learn if it is infact a ground leak or just another faulty batter(which is HIGHLY doubtful) but its just a suggestion..
do a parasitic current drain test. u hook up a dmm in series with the neg post of batt and the cable when the car is off. it should not read more tha 50ma. make sure ur amp fuse can hadle at least 10 amps or 20 just incase,u dont want to blow the fuse
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cr-x-91 »</TD></TR><TR><TD CLASS="quote">do a parasitic current drain test. u hook up a dmm in series with the neg post of batt and the cable when the car is off. it should not read more tha 50ma. make sure ur amp fuse can hadle at least 10 amps or 20 just incase,u dont want to blow the fuse</TD></TR></TABLE>best advice. If you are getting parasitic drain over what is normal then you will need to find out where it is. The best way to localize it is by checking all the circuits through the fuse box.
Try this.....
Take a test light and unhook the neg post on the battery hook the test light up to the neg post and put the other end in the cable. If there is some kind of draw on the battery then it will light up. Then you can remove fuses and see which system is giving the draw....then you have a idea where it is. Then with that fuse back in you can unplug the items in that system to see where it is.
BIG_WILL
Nov 16, 2008 07:06 PM
ID_ten_T
Nov 2, 2004 11:24 PM
