Car stalls when at stop while AC is on....
Old Jun 27, 2007 | 08:20 PM
sPaRk'iT's Avatar
Default Car stalls when at stop while AC is on....
My buddy bone stock 95 Accord would stall and sometimes die at a stop if the AC is on but if the AC is not on car would not die, i need dome advise where to start to look for the problems i'm thinking its the alternator...
Old Jun 27, 2007 | 08:24 PM
JDM_DC4_Fanatic's Avatar
Default Re: Car stalls when at stop while AC is on.... (sPaRk'iT)
The alternator charges the battery, it would have nothing to do with the AC compressor making the car stall out.
Is the compressor locking up? Can you increase the idle with the AC on and the car stays running? or is it as soon as you turn on the compressor the car dies instantly?
Old Jun 28, 2007 | 01:32 AM
sPaRk'iT's Avatar
Default Re: Car stalls when at stop while AC is on.... (JDM_DC4_Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">The alternator charges the battery, it would have nothing to do with the AC compressor making the car stall out.
Is the compressor locking up? Can you increase the idle with the AC on and the car stays running? or is it as soon as you turn on the compressor the car dies instantly?</TD></TR></TABLE>
I dont think the compressor is locking up the AC still blow cool and yes if you increase the idle the car will still run.
Old Jun 28, 2007 | 12:42 PM
TOP END MS's Avatar
A/C i beleive will lower the idle. But it seems the idle is low to begin with. Id check vacuum hoses for leaks.
Old Jun 28, 2007 | 01:12 PM
The-Kid's Avatar
Default Re: (TOP END MS)
I had this happen before. I just kept revving the engine for a while. drove around and it was fine again. It happens to me when I don't turn on my AC for a long time. It could be as simple as that. Other member's reply are still good too.
Old Jun 28, 2007 | 06:23 PM
hondadude's Avatar
is the idle air boost valve working?
What is the idle RPM with the car in park?
What is the idle RPM with the car in park and A/C on?
What happens to the idle RPM when you step on the brake pedal?
Has the IACV ever been cleaned or the throttle plate?
carlove
Acura TSX
Jul 11, 2018 06:01 AM
Davidss
Jul 16, 2009 05:51 AM
melsun_ap1
Sep 14, 2007 06:59 PM
tub_sephiroth
Jun 27, 2005 11:13 AM
jlamaster
Oct 1, 2004 07:12 PM
