lil help with Ignition Timing Adjustment Connector Input
Old Jun 27, 2007 | 08:00 PM
ivanson's Avatar
Default lil help with Ignition Timing Adjustment Connector Input
I have a 88hf and i swaped an 88si on it.
even ecu is off a 88.
and when i go to jump the connector it doesnt work.
the check engine doesnt stay on.
and i looking at a ecu wiring diagram and
found out that the B20 pin which is brown wire at the ecu
is the timing adjustment connector.
so my question is that if i could cut the wire from near the
ecu and be able to ground it to chasis in order to get the cel to stay on???
since i think there is an open within the wiring..
anoble1
Jan 17, 2026 08:26 PM
bcjjones
May 29, 2015 08:22 PM
blazzer
Apr 14, 2010 10:48 AM
BIG RICH
Jun 22, 2003 05:03 PM
g5r
Apr 7, 2003 08:51 PM
