HOW DO I Change the Main Relay???
Old Jun 27, 2007 | 07:39 PM
Andy Lyons 91's Avatar
Default HOW DO I Change the Main Relay???
I have 91 hatch with an Si swap...the car recently stopped running. Did the engine swap 3 days ago..it was running then out of nowhere it stalled...i have no idea what it is. I checked the essentials...air,fuel and spark. Its getting air...But its not getting spark...alot of people told me to change the main relay but i dont kno how.
Old Jun 27, 2007 | 07:41 PM
DenzComp's Avatar
It's a little box above the hood latch...under the dash...Little square box. Before you take the screws out and everything...just unplug yours and plug in another one and let it hang. No sense in taking screws out if that isn't the problem.
Old Jun 27, 2007 | 07:42 PM
crxforum's Avatar
Default Re: HOW DO I Change the Main Relay??? (Andy Lyons 91)
Remove the coin tray from under the dash.
You will see a black box on the left under there.
Thats the main relay.
Take a 10mm socket and remove the bracket at the bottom of it.
Unplug it from the harness.
Take your new one that you got from Honda (the only place that I know of to get them) and plug it into the harness.
Then mount it back in with the 10mm bolt.
Start up your car.
CRX Forum
Old Jun 27, 2007 | 07:53 PM
Default Re: HOW DO I Change the Main Relay??? (crxforum)
Does it say anything on the box?....any wires coming out of it?...if so what color?
Old Jun 27, 2007 | 07:55 PM
crxforum's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andy Lyons 91 &raquo;</TD></TR><TR><TD CLASS="quote">Does it say anything on the box?....any wires coming out of it?...if so what color?</TD></TR></TABLE>
Its a black box. I think it says on it Mitsuba or something like that. It has a plug on it that you just depress the tab on it and pop off the plug. Then take your new one and plug it in and youre good to go. No more than a 10min job if that.
CRX Forum
Old Jun 27, 2007 | 07:56 PM
DenzComp's Avatar
I'm not 100% on this....but I'm pretty sure it's black. I cannot tell you what color the wires are, or what the box says. You can't miss it man...lean down and look under the dash...right above the lever to pop the hood. It has a bracket hooked to it...and a plug.
If you have another one...unplug the original...and plug your new one in it.
Old Jun 27, 2007 | 07:57 PM
sneakerfern's Avatar
its black i believe should read "mitsuba" gl!
Old Jun 27, 2007 | 07:58 PM
DenzComp's Avatar
Echo?
Old Jun 27, 2007 | 08:05 PM
nihad's Avatar
It will have a # like 0063 i beleve 7wires
Old Jun 27, 2007 | 08:30 PM
Ermil's Avatar
Default Re: (nihad)
They are available after market. You can get the mitsuba relay. It's the same as Honda's relay, without a stamp that says Honda.
Old Jun 27, 2007 | 10:25 PM
Pee Wee's Avatar
Default Re: (Ermil)
you can also resolder your broken unit. takes all of 5 minutes and is free
HondaDNA93
Jun 5, 2008 09:57 PM
tpot90
Mar 7, 2008 12:50 PM
way2much
Oct 10, 2007 05:35 PM
EKHWhat
Mar 17, 2007 11:41 AM
ratbelly
Jul 29, 2005 07:12 PM
