I'm looking to install my own springs
Old Jun 27, 2007 | 06:58 PM
Bruce Banner's Avatar
Default I'm looking to install my own springs
Are there directions somewhere?
I got a 4th gen
TIA
Old Jun 27, 2007 | 07:37 PM
fw190bvi's Avatar
Default Re: I'm looking to install my own springs (Bruce Banner)
go to your local autoparts store and by a haynes or similar manual.
it essence: take off wheels. unbolt everything you can see that is holding in the shock/spring unit. remove unit. rent a spring compressor to remove spring. add new spring. put back in. get an alignment
Old Jun 27, 2007 | 08:29 PM
JDM_DC4_Fanatic's Avatar
Its pretty simple.
Fronts:
Raise car, and rest on jackstands.
Remove wheel
Remove lower shock frok bolt (17mm bolt going through the FLCA)
Remove the shock fork bolt (14mm bolt at the top of the fork)
Remove the fork from the strut.
Remove the 3 14mm bolts from the top of the strut tower, drop the shock, and slide out of the way.
Using a spring compressor, compress the OEM coil, undo the shock nut, remove the top mount, remove the spring and carefully release the tension on it. Place the new spring on the shock, reinstall the top mount and tighten the bolt.
Rear shocks.
raise and support the rear of the car, remove the lower shock bolt (1 17mm bolt)
Remove or pull back the side panels in the trunk and fold down the seat.
Remove the 2 14mm bolts on the top of the rear strut tower and the strut will fall out. Changing the spring is the same in the rear.
Old Jun 27, 2007 | 10:31 PM
wed3k's Avatar
that pretty much sums it...be sure to crack loose the upper strut bolts so that you wont have a helluva time doing it with the strut out of the car.
Old Jun 28, 2007 | 09:20 AM
Default Re: (wed3k)
o.k cool, what tools will I need, so I know to have all the tools when I do it.
Old Jun 28, 2007 | 12:28 PM
TOP END MS's Avatar
That sums it up, but is still WAY off. Use a manual and make absolutely certain, you torque all your bolts back to the EXACT OEM specs. Also the wheel should be raised into the possition as if the vehicle was on the ground before you tighten anything.
Old Jun 28, 2007 | 03:36 PM
jooch's Avatar
remember to do alignment after
mo tinkering, less straightness
Old Jun 28, 2007 | 05:12 PM
Default Re: (TOP END MS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOP END MS &raquo;</TD></TR><TR><TD CLASS="quote">That sums it up, but is still WAY off. Use a manual and make absolutely certain, you torque all your bolts back to the EXACT OEM specs. Also the wheel should be raised into the possition as if the vehicle was on the ground before you tighten anything.</TD></TR></TABLE>
Actually, its not way off, its exactly how I did it on my car. I'll even go take pics, since Bruce banner is a nice guy
First, remove the 17mm bolt that holds the shock fork to the lower control arm. The bolt is pictures here:
Then, remove the 14mm bolt that holds the top shock fork on.
Then Push down on the control arm, and wiggle the shock fork off, and slide it forward, or remove it.
Remove the 2 12mm bolts that hold the brake line to the shock
From under the hood, remove the 3 14mm bolts that hold the strut in, and it will drop, and it can be removed from the car.
After its out of the car, change the spring, and possibly the shock as well, and reinstall is the reverse.
Required tools:
Socket for lugs
17mm wrench
17mm socket
14mm socket
19mm socket (for shock, if you plan to change the spring yourself)
Spring Compressor (if you plan on changing your own springs)
Modified by JDM_DC4_Fanatic at 6:39 PM 6/28/2007
Old Jun 28, 2007 | 08:59 PM
wed3k's Avatar
id suggest an alignment after the springs settle (if he is lowering the vehcile)
Old Jun 29, 2007 | 08:19 AM
Default Re: (JDM_DC4_Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">
Required tools:
Socket for lugs
17mm wrench
17mm socket
14mm socket
Modified by JDM_DC4_Fanatic at 6:39 PM 6/28/2007</TD></TR></TABLE>
Awesome pics!
Thank you!
JDMEF
Jul 22, 2010 09:37 AM
civlxbro
Suspension & Brakes
Oct 4, 2009 07:51 AM
Lil Gnome
Jul 12, 2008 10:27 AM
SoullessJapaneseMachine
Jun 19, 2008 09:56 AM
SpoonREVS
22
Sep 9, 2004 09:21 PM
