i dont think my brakes are supposed to do this (vids)
Old Jun 27, 2007 | 06:12 PM
361 accord's Avatar
Default i dont think my brakes are supposed to do this (vids)
ok so its REALLY LOW quality (didnt check settings before shooting) but i think the brakes are dragging
even with the car turned on (yes i jacked up the *** end and spun the tire)
but it spun a little longer
Old Jun 27, 2007 | 06:19 PM
The-Kid's Avatar
Well, it seems it has too much resistance. Was it easy spinning it? I know on my 96, the wheel spins a lot more turn than yours. Handbrake all the way down? maybe there is some junk that got in between. Take off your caliper and spin it, sticky wheel bearing?
Old Jun 27, 2007 | 06:21 PM
02 accord's Avatar
Default Re: i dont think my brakes are supposed to do this (361 accord)
I'd say dragging just a bit more than normal. Might be normal tho. It's definitely not real bad.
Old Jun 27, 2007 | 06:27 PM
361 accord's Avatar
Default Re: (The-Kid)
not easy to spin, no
handbrake was all the way down
could you hear the scraping sound when the top of the H goes past the caliper??? i think the rotors may be warped? but i drive slow (ask 02 accord how slow i drive) haha
thats what i was thinking, the wheel bearings, idk if they are lifetime greased or if thats regular maintenance
Old Jun 27, 2007 | 06:42 PM
02 accord's Avatar
Default Re: (361 accord)
Maybe you drive too slow...Try speeding it up a bit to get the grease moving around the bearing. Then report back with your findings. If that doesn't work, you can always grease up the brakes. That should keep them from dragging so much.
Oh yea, grease up the caliper pins, those could be causing the caliper to stick and drag.
Old Jun 27, 2007 | 07:52 PM
dleccord's Avatar
Default Re: (02 accord)
could be warped, could be new pads maybe.
Old Jun 27, 2007 | 08:21 PM
JDM_DC4_Fanatic's Avatar
Default Re: (dleccord)
I dont think its the wheel bearing. Although it is sealed, it wont make noise spinning that slow unless its about to fall out. Another way to check for a wheel bearing that is on the way out, is to have someone spin the wheel, and you gently hold the traling arm. If the bearing is bad, you will feel the vibration through your arm.
It sounds to me like its time for new pads and rotors. It my be just the poor video quality, but the rotors look like they were very heated for quite some time, and perhaps the pads are now glazed. The rotor deffinatly sounds like its starting to warp based on the sound its making.
I would suggest new pads and rotors, and a caliper serive like suggested previously. lube the sliders on the caliper bracket and make sure that evertything is moving freely.
Old Jun 27, 2007 | 09:20 PM
SuShiBoiiii's Avatar
Default Re: (JDM_DC4_Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">
It sounds to me like its time for new pads and rotors. It my be just the poor video quality, but the rotors look like they were very heated for quite some time, and perhaps the pads are now glazed. The rotor deffinatly sounds like its starting to warp based on the sound its making. </TD></TR></TABLE>
MooreJo02
Mar 17, 2018 02:24 AM
mouab18c1
Suspension & Brakes
Mar 3, 2009 08:56 AM
JRizEJ6
11
Jul 11, 2008 07:25 PM
TmpltnPck
Dec 13, 2004 09:30 PM
SunkistRex
Mar 21, 2004 08:06 PM
