racing windshield
Please explain exactly what you are trying to accomplish, what the car is going to be used for, your current and future setup, etc. Playing around with the windshield is something that should be considered carefully.
i'm taking my car out of the road so i can use it at the track only and mine windshield is broken so i want to replace all my windows with racing windows and i heard i can get all the materials at home depot but i dont know wat the window is made of
you dont need it. if ur using it strictly as a track car, u still dont need it on the windshield. u can do maybe the rear windows but i wouldnt touch nething up front.
Stick with a glass windshield. When your "racing" and a rock flies through your lexan windshield and kills you or leaves you with one good eye you'll wish you'd had safety glass.
Plexiglass.
Though that's not road legal. That's what they use in funny cars.
Though if you're looking for weight reduction by buying a light weight windshield you're obviously not concerned about road legality 'cause it's a full blown race machine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lamafia ck »</TD></TR><TR><TD CLASS="quote">i run low 13 high 12 would a rock go in that easy </TD></TR></TABLE>
I've seen lexan break under very small amounts of force, i used to break it all the time at work with light kicks.
Stick with safety glass man, it's not THAT heavy.
How much do you weigh?
Punctures or breakage isn't the issue, since many track cars do indeed run Lexan windshields. The primary concern is the fact that the windshield is actually an important structural and safety component of the car. Unless you are running a full cage, I would strongly recommend that you stick with a properly installed factory glass windshield.
stick with glass its safer. and if u have never used lexan before i wouldnt even attempt to do ur windshield. ur not gonna get it right the first try. seriously its not worth the hassle or the lack of safety. dont use it ur not gonna get nething out of it especially on a hig 12 to low 13 second car. theres no point.
it then seems like its not worth it
and is gutting the hole car all the pannes take air bagg out helps or its not that big of deal
i weight about 150 and by the end of july i'll prob. b hitting low 11 high 11 with a new setup
i would just keep the interior in. its always more impressive to see someone run an 11 with full interior. but i usually take out everything from the front seats back. so if ur sitting up front it looks like it has a full interior but no rear seats or nething in the trunk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lamafia ck »</TD></TR><TR><TD CLASS="quote"> it then seems like its not worth it
i weight about 150 and by the end of july i'll prob. b hitting low 11 high 11 with a new setup</TD></TR></TABLE>
What's your current setup, and what'll your new setup be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lamafia ck »</TD></TR><TR><TD CLASS="quote">i'm taking my car out of the road so i can use it at the track only and mine windshield is broken so i want to replace all my windows with racing windows and i heard i can get all the materials at home depot but i dont know wat the window is made of
Weird.
Waste of time.
Consider more crucial things such as suspension and engine.
Weird.
Waste of time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trlstyle »</TD></TR><TR><TD CLASS="quote">...and stop shopping for materials for your "race car" at Home Depot.</TD></TR></TABLE>
ROFL, that just occurred to me. Good point.
