5th gear
Old Jun 27, 2007 | 04:13 PM
baboracus's Avatar
Default 5th gear
Today when i was paging through my manual about how to lift an engine and trans assembly out of the car, the manual transaxle page caught my eye. It looks like 5th gear could be swapped with relative ease (or possibly im looking at the final gear ratio?). Whichever gear is outside of the main transmission casing. I've heard of people switching around gears in their transmissions so i was wondering, what are all the parts neccessary to switch from an SI to HF 5th gear? Also, where could you buy something like that (other than obviously taking it out of an HF transmission)?
thanks
Old Jun 27, 2007 | 09:34 PM
lessonsinspeed's Avatar
You can buy a new 5th gear from any Honda dealership, and as an added perk, the pair are the cheapest gears. To my knowledge all you need is the countershaft and mainshaft 5th gears, but synchos may also be needed.
Old Jun 27, 2007 | 11:05 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: 5th gear (baboracus)
what year car you have?
I'll bet $5 you were looking at a Haynes or Chiltons manual and they were talking about the 84-87 Civic or 86-89 Teg tranny.
Not gonna happen on a 88-2000 tranny.
Old Jun 27, 2007 | 11:18 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: 5th gear (Mista Bone)
hmm, i thought you could just swap them also.. i have a trans i am building in my apartment where i did just that, swapped the countershaft si gear with an hf gear. I was kinda wondering myself whether the hf gear would cause issues. the mainshaft 5th and countershaft 5th gears seemed to mesh well, and i seem to remember reading that it is fairly common when you are swapping final drives to go to the hf gear to keep revs down, so i did it.
However, if mista bone says it doesnt work, i believe him. i just want details on whether it is even possible, because in my case, the money is spent on the hf gear. if it doesnt work at all, ill tear apart the transmission again and swap back to the si, so i can enjoy my 4800 rpm cruise at 80mph.
Old Jun 27, 2007 | 11:36 PM
Mista Bone's Avatar
D Tranny Guru
GearSETS.........
you stating you swapped just just the CS side gear means the mess was way off. If you didn't use the MS part of the gearset.......grindage IF the tranny will even spin over.
Wanna split a tranny down, remove both shafts, we can change 5th gear.
Old Jun 28, 2007 | 06:36 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (Mista Bone)
alright, well assuming i get the entire set for the hf 5th main shaft, syncro sleeve and all, is that going to work if i just swap it in? i forgot to mention the details of my setup.. its an 88 si cable trans with 4.9 FD.
I'm just looking to see if there is more to it, my interpretation is that i can swap the gearsets and everything works. if im missing something.. let me know..
Modified by sanimalp at 10:11 AM 6/28/2007
Old Jun 28, 2007 | 07:38 AM
Gearspeed-Performance's Avatar
Default Re: (sanimalp)
4.9 in a SOHC =
Old Jun 28, 2007 | 09:13 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (GearSpeedEF7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GearSpeedEF7 &raquo;</TD></TR><TR><TD CLASS="quote">4.9 in a SOHC = </TD></TR></TABLE>
oh yeah.. i cant wait to drive it.. need to figure out this 5th gear deal before that though.
Old Jun 28, 2007 | 12:05 PM
Mista Bone's Avatar
D Tranny Guru
even easier, just buy a .702 5th gearset,
I have a few.
Old Jun 28, 2007 | 12:37 PM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">what year car you have?
Not gonna happen on a 88-2000 tranny.</TD></TR></TABLE>
This is correct. There is no separate cover for the fifth gear end on the 88-91 trannies. you will have to remove the entire thing and crack the case open to get at fifth gear.
Old Jun 28, 2007 | 12:55 PM
Default Re: 5th gear (wiZCo)
Sounds old skoolish....with seperate 5th gears...the kind that are always toast because of lack of lubrication...glad Honda no longer does that!
Old Jun 28, 2007 | 02:43 PM
sanimalp's Avatar
$cat /dev/urandom
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">even easier, just buy a .702 5th gearset,
I have a few.</TD></TR></TABLE>
you have pm.
brlabrune
Feb 23, 2009 12:37 PM
trapstar101
May 16, 2007 07:34 AM
teg969
Apr 10, 2006 09:22 PM
CRXizSLAMM'd
Jul 14, 2004 05:14 PM
altoid 1.6
Dec 2, 2002 06:36 PM
