91 Si....CAR WONT START!!!....idk whats wrong with it.
Old Jun 27, 2007 | 02:38 PM
Andy Lyons 91's Avatar
Default 91 Si....CAR WONT START!!!....idk whats wrong with it. EFI??? Distributor?? ECU??/
Ok so i have a 1991 Si hatch...recently did an engine sawp. just a 1.6 Single Non Vtec. So the car has been running fine up until last night.. I was driving normally when out of nowhere the car just stalls out. I pull off the road. Tried to start it again and it will crank and turn but will not start. I check the temp, fuses etc... Idk what is wrong with it. Some say it is the EFI relay others say it is an ignition problem. I have no idea. If anyone has any ideas please let me kno. Thanks alot.!EFI??
Modified by Andy Lyons 91 at 4:12 PM 6/27/2007
Old Jun 27, 2007 | 02:49 PM
EF2_Sedan88's Avatar
Default Re: 91 Si....CAR WONT START!!!....idk whats wrong with it. (Andy Lyons 91)
did u check and see if u gettin any spark could be distributor 2 ...
Old Jun 27, 2007 | 02:55 PM
Default Re: 91 Si....CAR WONT START!!!....idk whats wrong with it. (EF288Gsr)
The distributor is brand new...some people are sayin it may be the efi because the car has a a swap from dual port to multi port fuel injection..
Old Jun 27, 2007 | 03:12 PM
EFHATCHMAN's Avatar
Hey bro, you really should check the distributor. I had this exxact same problem with my 91. Check to make sure that the set-screw that holds the rotor onto the dizzy shaft is still in there and tight.
Mine fell out and caused the same problem u just described.
Be careful though when u take the cap off that you dont lose the screw if it did fall out.
Just my opinion.
Good luck and let me know what you find.
Old Jun 27, 2007 | 03:17 PM
wickedEFguy's Avatar
If what was mentioned doesn't already work do this:
When you put the key into the "on" position the CEL light for a few seconds and you shoudl be able to hear the fuel pump prime. If that doesn't work then reseat the Main Relay or try a new one.
Also are you throwing any CEL's at all? Sometimes you can have a stored code and the CEL ph the cluster won't light up.
Old Jun 27, 2007 | 03:56 PM
sirtef9's Avatar
Default Re: (wickedEFguy)
if it were a dpfi before, its not an SI,,
Old Jun 27, 2007 | 04:00 PM
vdawg559's Avatar
so u did a conversion?...
Old Jun 27, 2007 | 06:21 PM
Default Re: (vdawg559)
yes i did a swap
eden12
Aug 9, 2013 05:33 PM
drplatypus
Mar 3, 2013 09:33 AM
Kelii671
Feb 10, 2010 01:51 AM
karmon
Mar 27, 2007 11:25 AM
Darel
Jul 31, 2005 02:57 AM
