Brake piston compression
Old Jun 27, 2007 | 11:54 AM
dkaye4's Avatar
Default Brake piston compression
Hey,
I'm trying to change the front brake pads on my 93 civic ex and I'm having trouble compressing the brake piston. The manual says to use a C-clamp to do it but I can't seem to get it to work. Any suggestions?
Old Jun 27, 2007 | 12:01 PM
DCSportEJ1Civic's Avatar
Default Re: Brake piston compression (dkaye4)
it may be seized. you would need a new caliper. you could try takin a small screwdriver and puilling up the boot and spray some wd-40 in there. but it will only be a temperary fix
Old Jun 27, 2007 | 12:02 PM
instructor74's Avatar
put your old pad back in use that to clamp against the other thing you can try is opening the bleeder but this will puss fluid out and you will need to rebleed the system. If you still cant get it to move you might need a to get aa reman caliper
Old Jun 27, 2007 | 12:43 PM
EG2Driver's Avatar
Default Re: Brake piston compression (instructor74)
Have you opened the bleeder valve? Have you taken the cap off the master cylinder reservoir off? Try doing that.
Remanufactured calipers are like $40 each anyways.
Old Jun 27, 2007 | 01:32 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Brake piston compression (EG2Driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2Driver &raquo;</TD></TR><TR><TD CLASS="quote">Remanufactured calipers are like $40 each anyways.</TD></TR></TABLE>
Incorrect. Try $80 - $100 or more depending on the application.
Old Jun 27, 2007 | 01:35 PM
B16b-EJ8's Avatar
Default Re: Brake piston compression (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
Incorrect. Try $80 - $100 or more depending on the application.</TD></TR></TABLE>
Correct...mine was $75.99 from autozone the reman from honda was $160 with a $50 core charge for my EJ8
Old Jun 27, 2007 | 04:58 PM
EG2Driver's Avatar
Well, i don't know where you guys go, but here at CarQuest, they're $44 a caliper + $50 deposit (CAD!!) for remanufactured calipers (new pistons, seals and sand blasted). And that was for my 94 Del Sol VTEC which has bigger calipers i believe which are kinda rare i guess.
hodsintegra23
Apr 6, 2022 11:12 AM
tazz29
Jul 9, 2008 10:52 AM
^LORTA^RACING
29
Dec 13, 2007 03:52 PM
CapYoda
11
Apr 23, 2005 03:08 PM
peterpeter
Jul 24, 2004 02:18 PM
