Looking for a part or a way to modify an existing part
Im looking for something like this:
http://www.cardomain.com/item/...=none
for my 2000 civic except im looking for one without the lower pocket or a removable lower pocket.
...in otherwords just the rectangle that covers the borders of the two DINs in the car.
Im looking for this cause i have a head unit installed, and i want to put this in the lower din:
http://cgi.ebay.com/ebaymotors...wItem
...that question was kinda confusin i kno...but any help is appreciated
ive found alot of kits like that for the civic but none with an open lower din
thanks
thanks
do you still have the factory metal radio brackets? i guess you are using an aftermarket radio install kit, but the originals should be there. just get rid of the kit and metal sleeve, and then mount the radio and the new trays to the oem bracket.
#13, http://handa-accessories.com/civic/civicaudio.pdf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hust1er »</TD></TR><TR><TD CLASS="quote">umm...ill check it out
thanks</TD></TR></TABLE>
He's right. ISO mount the deck and ISO mount the cup holders and you'll be set.
You may need to buy a trim ring for the bottom piece though.. One of these: http://cgi.ebay.com/Metra-Univ...wItem and modify it and attach it as needed...
Ditto both the above, use ISO mounting... http://www.installdr.com/Insta...5.pdf scroll down to "Remove Radio From Dash Assembly" mount the aftermarket HU the same way as the stock HU is mounted, you may have to file the mounting holes in the dash assembly, so after market HU sits where you want it.
Be very careful with the length if screw you use into the side of the HU.
94
94
Would anyone not recomend gettin the cupholder thing?
cause i basically juss want some better cupholders...since i need coffee in the mornin and the si cupholders are trash. i know i can also put in the 96-98 cupholders in but are they better then the si holders...cause it looks the only dif is a lid on top
You can put a cup holder there or a pocket or even a dummy plate, it really makes no diff.
Keep in mind your coffee is going to be very close to the face plate of your HU making access to it difficult and you do not want to know what coffee will do to the workings of the face plate, should you have to hammer on the brakes.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">No. Those cupholders are not designed for cups. They'll hold beans and spiders, and maybe a trinket or two, but definitely will not hold a cup. </TD></TR></TABLE>
way to be a smartass
...the si cupholders cant hold **** without them spilling...so i was juss askin bout the 96-98 ones with the lid and how well they actually hold drinks
if dont got nothin to say...dip
Calling someone that are helping you a smart-*** isn't going to get you a lot more help from any of us.
Before you put your foot in your mouth again check the post count of anybody you want to bad mouth again, and say your sorry.
We are here a lot trying to help, so if sometimes we get a little sarcastic, you will need to suck it up, and lol it off.
There is nothing that will get us pissed more then a no0b who can't take a little ribbing.
He is right, the cup holder sucks and isn't even good for the things he mentions.
94
94
Maybe you'd be happier with one of these:
I'm sure that will hold your pussified venti white chocolate mocha soy latte just fine....
OR...
Maybe you could put your coffee in one of these, then you won't have to worry about spilling...
Modified by B18C_EJ8 at 1:55 PM 7/2/2007
OR...
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
rofl hard.... you said trinket , lol. My parents use to have those cup holders back in the 80's. Here is my 11/2 cent. Go to the honda dealer and get one of those spill proof cups that fit the cup holder. There only $6.99. and they come in red with the honda logo.
"I'm sure that will hold your pussified venti white chocolate mocha soy latte just fine...."
Brahahahahahahahaha, I told you.
94
94
"I'm sure that will hold your pussified venti white chocolate mocha soy latte </TD></TR></TABLE>
so you have a problem with white chocolate lattes ??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by montvillefire22 »</TD></TR><TR><TD CLASS="quote">you can get a un face plat like the one you have to use with the del sol but in 2 din </TD></TR></TABLE>Please translate into English
