f22 turbo
Old Jun 27, 2007 | 09:42 AM
ryanmcdermit's Avatar
Default f22 turbo
i just bought a turbo for a stock f22 engine. what do i need to change if i was looking to run it at 6 or 7 psi and around 220 hp?
Old Jun 27, 2007 | 09:43 AM
Hawkze_2.3's Avatar
Default Re: f22 turbo (ryanmcdermit)
Uh....you just bought the turbo itself? Give us more details about the engine and the parts you have.
Old Jun 27, 2007 | 10:37 AM
Default Re: f22 turbo (Hawkze_2.3)
i have a Brand new Mitsubishi TD04HL-16T-8.5 turbocharger with 1 bar of booost set at 14.7 psi. i have 440 cc injectors and a fullexhaust system. The turbo came with a intercooler oil return kit manifold bov piping. It was everything except down piping. I talked to some people about how to lower the psi and they said i had the switch the spring. Other people said that i could just by a boost controler? But other than that what else do i need?
Old Jun 27, 2007 | 10:50 AM
Hawkze_2.3's Avatar
Looks like the only other major thing you're missing is tuning stuff. The most important part of any engine is the management, so you definately need to get something. Hondata, Crome, whatever you like...
The weak point on that F22 block is going to be the piston ringlands. If your tuner is good he may be able deal with 1 bar safely or he may not be able to. If not, yeah you should be able to change the wastegate spring to lower the boost (not an expert in internal gates myself ). As I understand it a boost controller will only let you raise the boost, not lower it.
Old Jun 27, 2007 | 07:33 PM
sigmiester's Avatar
i have a mitsu boosted f22 you can not put in a lower psi spring. internally gated wastegate turbos cant not be opened up. hahn racecraft makes a wastegate that is gated for 5 psi or u could just attach a, i dunno what you want to call it but, a hooked spring that will relieve some of the tension to the wastegate spring in theory lowering the pressure needed to open the wastegate. i would build the motor for higher boost it is easier because ur going to blow the motor eventually no matter what ur tuner does so u might as well blow the engine with 15 psi then 5 psi.
rez624
Nov 4, 2010 12:05 PM
civiclxb16a
Jul 22, 2005 09:01 AM
tealbubble
Feb 18, 2005 06:03 PM
quik sol
Sep 6, 2003 07:47 PM
Blindstuff
Jun 29, 2003 05:18 PM
