how to extend o2 sensor cable
Hi I just got a dc header for my Sol and I just noticed the o2 sensor isn't located in the same spot. It's down while the stock is up high. Is there a way to extend the cable? If so how? Thanks
or you could buy an extender
http://rywire.com/store/4wire-...d754e
or you can unwrap some of your harness and rewrap it with the o2 sensor by itself, it has enough length to make it behind the motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cimo463 »</TD></TR><TR><TD CLASS="quote">its fairly easy...your gonna have to cut and extend you wires with new wire and crimp them together</TD></TR></TABLE>
^easy way....cut n splice=]
Just did that today. It's a nice easy way that holds up really well if done correctly. Just make sure you recconect the correct wires together.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by germ07 »</TD></TR><TR><TD CLASS="quote">Hi I just got a dc header for my Sol and I just noticed the o2 sensor isn't located in the same spot. It's down while the stock is up high. </TD></TR></TABLE> is this the same for a 99 civic si?
i thought the emissions calcuations were done between O2 sensors, and the distance between the sensor is supposed to be a specific distance
but the op probably has a cat delete (idk why lol)
pollution FTL!!
pollution FTL!!
2slo2bst
10
Mar 20, 2006 09:51 AM
