how to extend o2 sensor cable
Hi I just got a dc header for my Sol and I just noticed the o2 sensor isn't located in the same spot. It's down while the stock is up high. Is there a way to extend the cable? If so how? Thanks
Re: how to extend o2 sensor cable (cimo463)
or you could buy an extender
http://rywire.com/store/4wire-...d754e
Re: how to extend o2 sensor cable (malubawla)
or you can unwrap some of your harness and rewrap it with the o2 sensor by itself, it has enough length to make it behind the motor
Re: how to extend o2 sensor cable (redhatch8u-up)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cimo463 »</TD></TR><TR><TD CLASS="quote">its fairly easy...your gonna have to cut and extend you wires with new wire and crimp them together</TD></TR></TABLE>
^easy way....cut n splice=]
Just did that today. It's a nice easy way that holds up really well if done correctly. Just make sure you recconect the correct wires together.
Re: how to extend o2 sensor cable (germ07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by germ07 »</TD></TR><TR><TD CLASS="quote">Hi I just got a dc header for my Sol and I just noticed the o2 sensor isn't located in the same spot. It's down while the stock is up high. </TD></TR></TABLE> is this the same for a 99 civic si?
Re: how to extend o2 sensor cable (ActionJackson)
i thought the emissions calcuations were done between O2 sensors, and the distance between the sensor is supposed to be a specific distance
but the op probably has a cat delete (idk why lol)
pollution FTL!!
pollution FTL!!
