vtec kick in late
Old Jun 27, 2007 | 07:30 AM
NOman0608's Avatar
Default vtec kick in late
i got a b16a motor in my EM1.
i have notice that the vtec is kicking in late.
First gear kicks in where its soppose to,
but in 2nd,3rd gear it kicks in at 6,500..
never tried kickin the vtec in in 4th and 5th...
what could be the cause of that?
thanks
Old Jun 27, 2007 | 07:32 AM
jpcrx's Avatar
maybe you have a modded ecu?
Old Jun 27, 2007 | 08:23 AM
ef_hatchback's Avatar
Default Re: vtec kick in late (NOman0608)
what ecu are you running???
Old Jun 27, 2007 | 10:00 AM
drSquish's Avatar
Search.
VTEC is engaged by the ECU. Unless you buy a mini-me swapped civic with VTEC wired to a button on your dash, but we won't get into that. Anyway, several factors help the ECU make the decision of when should VTEC engage. Normally it is engaged at 5500~ RPMs.
Off the top of my head- oil pressure, engine load, and traveling speed are three of those factors. I don't feel like searching for ya this time.
Old Jun 27, 2007 | 10:11 AM
NOman0608's Avatar
Default Re: vtec kick in late (ef_hatchback)
i am running a stock ecu
Old Jun 27, 2007 | 10:22 AM
deadline's Avatar
vtec is prob kicking in normaly...just get your eyes checked
Old Jun 27, 2007 | 10:36 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (deadline)
Unless I'm mistaken vtec kicks in at slightly differen't rpms in each gear because the load on the engine is different. Thus making the oil pressure slightly different.
If it's usually around ~6,500 then you're fine.
Old Jun 27, 2007 | 11:28 AM
Bev-Tech Inc.'s Avatar
Do you have an oil pressure guage? Vtec should come on at the same rpm every time.
The factors are RPM, Throttle Positio.n, Vehicle Speed, Load, and Oil Pressure. If all these things are in order Vtec will come on, if one thing isa out of wack it won't. But will always come on at the same RPM
carlossolorzano
Nov 26, 2010 10:03 AM
ef kyle
Sep 14, 2006 11:04 AM
DOHC-V-TEC-DA
Feb 3, 2006 06:03 PM
b.serious
Sep 4, 2005 01:25 AM
digitalhav0c
Apr 9, 2002 11:05 AM
