can itr pistons fit with a itr head with stock ls rods in a ls block
Assuming you have an LS crank, yes, it will fit just fine. I actually did a reversal setup.
C5 block
LS crank
LS rods
ITR pistons
ITR head
Works out just fine. Shaved 0.007" off the block which yields nearly 11.5:1 compression. Good luck, will make some nice power.
C5 block
LS crank
LS rods
ITR pistons
ITR head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs »</TD></TR><TR><TD CLASS="quote">Assuming you have an LS crank, yes, it will fit just fine. I actually did a reversal setup.
C5 block
LS crank
LS rods
ITR pistons
ITR head
Works out just fine. Shaved 0.007" off the block which yields nearly 11.5:1 compression. Good luck, will make some nice power.</TD></TR></TABLE>
I plan on doing the same exact setup..... just not on 81mm w00t
C5 block
LS crank
LS rods
ITR pistons
ITR head
Rex89
Jun 27, 2007 06:45 AM
