89 crx what first?
Old Jun 27, 2007 | 02:56 AM
newhondaguycrx's Avatar
Default 89 crx what first?
just bought the crx with 135,000 on the odom what would be the best first mod im new to your world thats why im asking its a d16 block with v-tec already has a controler for vtec..................???????????
Old Jun 27, 2007 | 05:58 AM
mahatma's Avatar
Default Re: 89 crx what first? (newhondaguycrx)
first mod for what?
i'd do suspension 1st
Old Jun 27, 2007 | 06:06 AM
DenzComp's Avatar
Default Re: 89 crx what first? (mahatma)
First thing I'd do would be to change the oil. No matter what vehicle I buy, no matter how clean the oil looks, I change it ASAP. Filter too. Better to be safe than sorry.
Check all other fluids while you're at it.
Old Jun 27, 2007 | 06:15 AM
CRX Toad's Avatar
First thing anyone should do is regular maintenance like inspection of belts, water pump, compression test, plugs, wires, cap, rotor, bushings, battery, battery cable/grounds, shocks, and nut and bolt car. Then replace anything that looks like it has been there for a while, change all fluids (oil, coolant, brake fluid).
Once you know the car is solid then rock on with other modifications like suspension, motor, etc. Why drop money into a car when you don't know it is solid is stupid.
The DX Rex
17
Dec 19, 2004 12:50 PM
GroundZer0 336
Jun 29, 2003 03:46 PM
Evan55
Dec 19, 2002 04:48 PM
Type R 98-0352
Aug 11, 2002 01:41 PM
acatak
Jul 16, 2002 06:18 AM
