intake resonator
Old Jun 27, 2007 | 12:48 AM
slickshifter's Avatar
Default intake resonator
I've heard you can remove the intake resonator so that you can here the engine a little better without getting an after market intake. Where is it on a 97' prelude? How do you remove it? thanks.
Old Jun 27, 2007 | 05:34 AM
mattsnooz's Avatar
Default Re: intake resonator (slickshifter)
it should be right under your stock air filterbox (if its like 4th gen)
and yes it is usless once you put aftermarket intake. Actually its usless all together!
RIP THAT $HIT out!!!
Just plug the vacuum line going to the intake control diaphram (line comes from IM on 4th gen)
Old Jun 27, 2007 | 09:41 AM
What did you use to plug the vacuum line? So is it in the fender well? Does it just un-bolt? thanks for the feedback. Anyone know of a do it yourself for this with pics? thanks again.
Old Jun 27, 2007 | 09:43 AM
Hawkze_2.3's Avatar
Default Re: (slickshifter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slickshifter &raquo;</TD></TR><TR><TD CLASS="quote">What did you use to plug the vacuum line? So is it in the fender well? Does it just un-bolt? thanks for the feedback. Anyone know of a do it yourself for this with pics? thanks again.</TD></TR></TABLE>
Use a vacuum cap from the auto parts store. It is in the fender well, just unbolt and remove it...
Old Jun 27, 2007 | 11:24 AM
what size vacuum cap?
Old Jun 27, 2007 | 12:41 PM
jmai86's Avatar
Some bolts can be tricky to get to to unbolt the resonator. Just feel around and you'll get it. I just capped it by screwing a bolt into the rubber vacuum line! Ghetto but works.
And yeah you'll hear a deeper tone at mid and high RPMs. Sounds sweet
Old Jun 27, 2007 | 01:20 PM
mattsnooz's Avatar
Default Re: (jmai86)
torque a larger sized bolt down the vacuum hole and E-tape the head onto hose (aka ghetto rig it) lol. My resonator had 4 bolts, two of which were tucked up high behind the twin tubes that go up into fender. Like he said you just have to feel around for them. I believe they were 10mm
Modified by mattsnooz at 7:51 PM 6/28/2007
Old Jun 28, 2007 | 02:30 PM
Got it finished in a about and hour and change yesterday, sounds good. Capped the vacuum line, and done. Not having this vacuum isn't going to do anything negative right?
Old Jun 28, 2007 | 06:51 PM
mattsnooz's Avatar
No, the vacuum controls the diaphram that you might have noticed when taking it all out (diaphram controlled switch valve) The diaphram opens and closes that valve you see in resonator piping. If you cap it off, no vacuum loss occurs so pressure is maintained in the intake manifold. If you don't cap it, its essentially a vacuum leak and make your car idle a bit wierd (nothing major)
Old Jun 28, 2007 | 07:45 PM
CAN97SH's Avatar
Resident Hoser #1
Community Builder
Community Influencer
Here ya go. Everything you need to know and how to do it.
http://www.ntpog.org/mods/fift...shtml
oops, didn't see that you did it already
Modified by CAN97SH at 11:42 PM 6/28/2007
Old Jun 28, 2007 | 09:51 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slickshifter &raquo;</TD></TR><TR><TD CLASS="quote"> Not having this vacuum isn't going to do anything negative right?</TD></TR></TABLE>
What do you mean?
Old Jun 29, 2007 | 11:21 AM
Default Re: intake resonator (CAN97SH)
that's is exactly where I got my directions from. Pretty basic, thanks for the help guys.
Accordin2me
Aug 5, 2010 03:02 PM
MilanoLude
Sep 24, 2007 03:19 PM
sony224422
Jul 21, 2006 02:43 PM
roadawg
Oct 25, 2003 05:39 PM
