d16z6 head potential???
can the z6 head hold 300-350 whp...it will have a port and polish...new valve springs, valves...and cam...will i need to change out the valve seat guides...or anything? if its best i do...how do i exactly remove and replace them?...may be a dumb question...but i prefer to know the correct way to do it
From what I've seen the Z6 head is good to about 380whp, but the Y8 head will flow more. With extensive porting, anything is possible - but your goal of 350ish whp is reachable. The block is more of a trouble spot. Rods and pistons help, but you might run into problems with the head not sealing and the sleeves moving around. IMHO, anything over 300ish whp - get it sleeved.
There are LOTS of un-sleeved Z6s making upwards of 300whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJProject »</TD></TR><TR><TD CLASS="quote">From what I've seen the Z6 head is good to about 380whp, but the Y8 head will flow more.</TD></TR></TABLE>
What?
What?
im stickin with the z6...but i just want the 300-350 range...can i achieve that with a mild port and polish...and some block guards...and so forth...or will i need to look more into some higher performance parts....its gonna be a daily driver as well...so its just gonna be during high boost on those nights filled with v8 racin...
OCsurfer
May 23, 2011 08:02 AM
Beasty91Hatchy
Oct 28, 2010 01:51 AM
baphomet
Jun 7, 2006 12:28 PM
