LS/GSR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raaawrz »</TD></TR><TR><TD CLASS="quote">yessir. you'll be fine.</TD></TR></TABLE>
+1
+1
WHY WOULD YOU USE GSR TRANNY WITH TURBO SETUP you should use LS tranny for the longer gears......dude common.....LIKE even i knew that.....psh......for realz hommie....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g0tgot »</TD></TR><TR><TD CLASS="quote">WHY WOULD YOU USE GSR TRANNY WITH TURBO SETUP you should use LS tranny for the longer gears......dude common.....LIKE even i knew that.....psh......for realz hommie....</TD></TR></TABLE>
because people want better acceleration
Longer gears aren't always better... you might have a higher top speed but it will take longer to get there...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">
because people want better acceleration</TD></TR></TABLE>
just like he said...
and yes you will be fine with the same axles
hey did you build it yourself...if you did could you give me the torque specs for the bolts holding the rods, will just give me all the specs for the block....thanks...just email me the specs at touintegra1@msn.com
