Check out my Motor Mounts - diagnosis needed..
Old Jun 6, 2002 | 03:16 PM
navin's Avatar
Default Check out my Motor Mounts - diagnosis needed..
Sorry for the crappy pics , bad digi cam + bad lighting = these pics. anyway this has been sort of a concern with me, my timing side mount (the metal things that stick up) seem to be bent, well one at least. Im not sure if they are supposed to be upright or not.
I fit the Timing Side Bracket on, and it slid on perfectly. So do you think I have a problem or not.
*PICTURES*
Old Jun 6, 2002 | 03:28 PM
Jackson's Avatar
Default Re: Check out my Motor Mounts - diagnosis needed.. (navin)
They should be perfectly straight, if that is what you are asking. But if it holds the mount on there securely, you should be fine.
Old Jun 6, 2002 | 03:30 PM
navin's Avatar
Default Re: Check out my Motor Mounts - diagnosis needed.. (Jedi Master)
They are straight up - but the one that is farther back sits toward the left. I mean the bracket slides through the it and fits fine and lines up with where the bolt goes. So do you guys think this is fine?
Old Jun 6, 2002 | 03:57 PM
Kamin's Avatar
yea i would GENTLY pound it to as straight as possible
but you should be fine.
Old Jun 6, 2002 | 04:06 PM
navin's Avatar
Default Re: Check out my Motor Mounts - diagnosis needed.. (KAMiN)
Gonna try that tommorow.. Thanks for the time Tony and Kamin. w00p last day of school tommora
Old Jun 6, 2002 | 07:14 PM
Big Teggie's Avatar
Should be fine as long as the mount slides on easliy.
Old Jun 7, 2002 | 04:21 AM
navin's Avatar
Default Re: Check out my Motor Mounts - diagnosis needed.. (Big Teggie)
It does..
Old Jun 7, 2002 | 07:10 AM
DR. ON POINT's Avatar
Banned
if it works than it works, leave it alone
Old Jun 7, 2002 | 04:22 PM
acuracing's Avatar
It doesn't look normal. I guess if it works then just leave it be. I would probably replace it though. Better safe than sorry.
Old Jun 7, 2002 | 04:24 PM
navin's Avatar
Default Re: Check out my Motor Mounts - diagnosis needed.. (acuracing)
How would I replace that. HOw can i take that mount off anyway. I just hope its not like welded on there or something.
Old Jun 7, 2002 | 07:22 PM
97hb's Avatar
It treads in. You need two nuts on top of each other and use that to take the studs out. Studs were like $7.
[Modified by 97hb, 10:22 PM 6/7/2002]
Old Jun 7, 2002 | 07:29 PM
navin's Avatar
Default Re: Check out my Motor Mounts - diagnosis needed.. (97hb)
I see- that wll be my project for tommorow. Thanks
Old Jun 7, 2002 | 07:33 PM
97hb's Avatar
Is your mount bent also? If you need I have an ls mount (pretty sure its the same) with the studs already in it. You pay for shipping.
Old Jun 7, 2002 | 08:26 PM
navin's Avatar
no the mount is fine - i bought one from some on here.
ChangoLoco
Dec 20, 2013 04:29 PM
macmac89
10
Sep 27, 2010 02:21 PM
gottabfast
Feb 18, 2009 04:35 PM
O16581724 5 2 5
May 30, 2005 10:35 PM
