maintenance help
Old Jun 26, 2007 | 05:26 PM
howard-zhang's Avatar
Default maintenance help
mine is 96 accrd ex, has 177k mileage, what kind of maintenance should I do with this car? Especially on the engine, thanks everybody...
Old Jun 26, 2007 | 05:38 PM
JDM_DC4_Fanatic's Avatar
Default Re: maintenance help (howard-zhang)
what have you done already? If you just got the car, I would check everything.
Air filter
Fuel Filter
PCV valve
Plugs
Wires
Cap
Rotor
Timing belt
Serpentine Belt
Tire Pressure
Oil Change
Valve adjustment
Lots of things that could be checked over, depends on what has already been done to the car.
Old Jun 26, 2007 | 05:44 PM
Default Re: maintenance help (JDM_DC4_Fanatic)
i did changed the air filter, fuel filter, oil change. I have no idea abt the valve adjustment, Serpentine Belt and pcv valve, how should I do with those?
Old Jun 26, 2007 | 07:39 PM
hb_guy's Avatar
accord faq can answer your tune up questions.. many of us can answer in detail but it can get lengthy.. just search or use the accord faq at the top of the page..
g/l
Old Jun 26, 2007 | 08:48 PM
The-Kid's Avatar
Default Re: maintenance help (hb_guy)
The PCV is the one going on top of your valve. It has a hose connected to the intake manifold. Since your Accord is kinda high mileage, I would just replace it. But to check it, pull it out of it's rubber grommet and shake it. If it rattles, it is good. If it rattles a little, kinda sticky, use carb spray and spray into it. If it doesn't move at all, replace.
Belts, check for crack, inspect the belt. See if theres proper tension. I think 1" deflection up and down from the longest between 2 pulleys.
Valve adjustment is in the Accord FAQ
Old Jun 26, 2007 | 09:57 PM
Mjfan12's Avatar
how difficult are valve adustments? I mean do you tighter'loosen some bolts and use a feeler guage to ensure proper clearences? thats all or is it more than that?
Matt00
Feb 18, 2009 12:04 PM
bboixtc
Nov 5, 2006 10:28 AM
dman81
Mar 9, 2005 01:51 PM
EJ1_519
Apr 30, 2004 11:11 AM
BoostFrenzy.com
Apr 8, 2004 08:09 AM
