Finding the right bolt.
Old Jun 26, 2007 | 04:37 PM
Libertariat's Avatar
Ek Forever y0!
Default Finding the right bolt.
So the two bolts that hold on the bottom section of the front bumper are stripped/all jacked up.
I think it's #20 on this list.
http://www.hondaautomotivepart...UMPER
Any help would be appreciated.
Just trying to confirm so I don't get the wrong bolt at $3 each.
Modified by ek forever guy at 5:47 PM 6/26/2007
Old Jun 26, 2007 | 04:38 PM
ke98248's Avatar
Default Re: Finding the right bolt. (ek forever guy)
Ahh man, no helms? I will check ...\
Not sure if haynes will have it
Ek Forever y0!
Default Re: Finding the right bolt. (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">Ahh man, no helms? I will check ...</TD></TR></TABLE>
Doh, I have a haynes. I'll look in that.
Old Jun 26, 2007 | 04:45 PM
ke98248's Avatar
I checked in my haynes and the back/front bumper has two screws that are next to each side clip on either end of the bumper... Those are generic screws (5 X 20). It's the exact same size screw that hold on the front bumper ends though..
There are 4 bolts that connect the rear/front bumper beam to the absorber, which connects tothe back bumper. That bolt is: 12 X 1.25MM (40 lbl-ft)
Then seven special clips..
Darn, too late!; but those bolts are the same for the front..
Old Jun 26, 2007 | 04:48 PM
Ek Forever y0!
(It's the front bumper, should have mentioned earlier, it's fixed now)
Old Jun 26, 2007 | 08:16 PM
Ek Forever y0!
Can anyone else confirm? If the hardware store doesn't have it, i'm going to need to order the bolt. So If you think it is or isn't the one I think it is, please, chime in.
Old Jun 26, 2007 | 08:17 PM
HCivicSi23's Avatar
5x20. Just nail it back on, who cares?
Old Jun 26, 2007 | 08:19 PM
Ek Forever y0!
Default Re: Finding the right bolt. (HCivicSi23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCivicSi23 &raquo;</TD></TR><TR><TD CLASS="quote">5x20. Just nail it back on, who cares? </TD></TR></TABLE>
I do, because I'm concerned about stripping the hole.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">
Old Jun 26, 2007 | 08:22 PM
HCivicSi23's Avatar
I know, I checked my Honda body manual ( best you can get ) and its a 5x20. If worse comes to worse, size it up at the hardwear store.
Old Jun 26, 2007 | 08:23 PM
Ek Forever y0!
I know, I checked my Honda body manual ( best you can get ) and its a 5x20. If worse comes to worse, size it up at the hardwear store. </TD></TR></TABLE>
You're not listening, "Do you think it is #20 on majestic hondas part list?"
Old Jun 26, 2007 | 08:28 PM
HCivicSi23's Avatar
Bottom section is so vaugue. Bottom lip? Main front bumper piece?
Old Jun 27, 2007 | 04:53 AM
Ek Forever y0!
Did you look at part 20 on the link I posted? It clearly holds on the bumper cover.
There's ONLY TWO bolts that hold on the entire bumper cover that are on the bottom side under the frame.
Old Jun 27, 2007 | 10:30 AM
Ek Forever y0!
Bump, I'm about to order.
# 20 BOLT B, BUMPER
Just trying to confirm if this is the right one.
Old Jun 27, 2007 | 10:44 AM
Jhonny Ricer's Avatar
Id go with number 19 get the assy and call it a day but Yessir you are corect that is what you are looking for.
Old Jun 27, 2007 | 10:49 AM
motor_man's Avatar
yea i just looked at mine thats the one # 20 BOLT B, BUMPER.......
Old Jun 27, 2007 | 10:59 AM
HCivicSi23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Did you look at part 20 on the link I posted? It clearly holds on the bumper cover.
There's ONLY TWO bolts that hold on the entire bumper cover that are on the bottom side under the frame.</TD></TR></TABLE>
Right. But the bumper spilts into pieces as you can see, but if your talking about the bumper as a whole... # 20 would be what your looking for. I am sure of it.
Old Jun 27, 2007 | 11:21 AM
Bev-Tech Inc.'s Avatar
#20 will do the trick....
Old Jun 27, 2007 | 11:50 AM
EL Vap133's Avatar
When I took my bumper off it had 10mm bolts with the metal washers. The rest were the usual plastic screws/fasteners.
Old Jun 27, 2007 | 12:37 PM
MDM's Avatar
MDM
Default Re: Finding the right bolt. (EL Vap133)
yup 20 it is fo sho
Old Jun 27, 2007 | 01:19 PM
Ek Forever y0!
Default Re: Finding the right bolt. (MDM)
Cool guys, thanks. Just wanted to confirm, I'm actually ordering two of the assy.
Old Jun 27, 2007 | 03:19 PM
MDM's Avatar
MDM
cool get me a pair too while ur at it
Old Jun 27, 2007 | 05:20 PM
Ek Forever y0!
Errr... Ended up being $20 for the two bolts after shipping and a "handling" fee.
So I'm just going to visit my local dealer or order some from a hardware store.
Old Jun 29, 2007 | 07:31 AM
MDM's Avatar
MDM
sucks huh.... well gl looking for the right price
Old Jun 29, 2007 | 08:32 AM
bwahha 20 bucks for 2 bolts that they could throw into an envelope and put a poststamp on lol made me laugh.
Old Jun 29, 2007 | 08:41 AM
pdiggitydogg's Avatar
its an m6 bolt...
just hit up the hardware store, get stainless pieces, fat washers, call it done
Probably will cost you $4
