door ajar light
Old Jun 26, 2007 | 04:33 PM
danteisme's Avatar
Loved
Community Favorite
Default door ajar light
ok, i was driving up the road, a normal straight road and my door light came on. i checked all of them and they were all closed. is there anything common that cuases this? or did one of my sensors just finally kick the bucket?
Old Jun 27, 2007 | 08:02 AM
davidv433's Avatar
Default Re: door ajar light (danteisme)
whatsup, below the door latches are little black rubber pins that you can push in take out the rubber cover , then remove the screw and make sure its not rusted, and check the wire on the inside of the pin, it might have come loose. remove the rust around where the screw goes in to make better contact.
Old Jun 27, 2007 | 10:00 AM
danteisme's Avatar
Loved
Community Favorite
Default Re: door ajar light (davidv433)
well, now in additino to my car thinkin the doors are open, none of the interior likghts work, trunk included. i checekd the fuse and it was junk, so i replaced it. as soon as it gets in there it pops the fuse.
Old Jun 27, 2007 | 02:10 PM
danteisme's Avatar
Loved
Community Favorite
anyone have a good idea where i should start? i dunno what would trigger the door ajar light AND blow my fuse for the INT. light.
Old Jun 27, 2007 | 02:58 PM
Blahblah718293's Avatar
im no electrician but it could be a short? im not sure.. i just this weekend installed a switch to override that door button. you could try disconnecting the wire and see if that works, but no more dome when you open your door.
Old Jun 27, 2007 | 08:03 PM
davidv433's Avatar
Default Re: door ajar light (Blahblah718293)
do you happen to have an aftermarket alarm installed in the car ? if not try removing the trunk and the dome light,and then rplace the fuse see if it blows again. gotta try to eliminate the short source, door pins work with a negative pulse, those shouldnt blow the fuse.
Old Jun 28, 2007 | 08:14 AM
danteisme's Avatar
Loved
Community Favorite
ok, i popped out the dome light and the door ajar light now works like normal. i tried replacing the fuse and it popped it again. does this mean my problem is behind my headliner with the dome light?
Old Jun 28, 2007 | 05:47 PM
davidv433's Avatar
did your remove the whole domelight assembly or just the bulb, the problem might be with the domelight switch, they wear out after time and cause a short.
Old Jun 28, 2007 | 09:49 PM
danteisme's Avatar
Loved
Community Favorite
Default Re: (davidv433)
i actually just removed the bulb, not the whole assembly
oh and i checked all the door ajar sensors, they're all good except for the one that is non existant(explains why the passenger door never activated the dome lights since ive owned the car haha)
Old Jun 28, 2007 | 09:55 PM
OC Geezer's Avatar
Default Re: (danteisme)
A Short or perhaps a bad ground that's causing it....i think. haha I hate wiring.
Old Jun 28, 2007 | 10:05 PM
danteisme's Avatar
Loved
Community Favorite
a friend of mine gave me this diagram. so now i gotta find where the red/white wire goes throught out the dash and find the bad one. i have a feelin theres a bad spot on here somewhere. but first, i will yank out the dome switch to see if that fixes it, like suggested a couple posts up
http://img.photobucket.com/alb...g.jpg
Old Jul 2, 2007 | 08:23 AM
danteisme's Avatar
Loved
Community Favorite
fixed
Old Jul 2, 2007 | 03:09 PM
davidv433's Avatar
what was it, the domelight shwitch ?
Old Jul 2, 2007 | 05:12 PM
danteisme's Avatar
Loved
Community Favorite
nope, i actually found it by accident. i went to remove my antenna to sand the car and behold. there are wires all melted together back there. one of which was the red and white stripped wire(just like the dome lights) so i cut out the bad, put in some new and amazing it works now. i have no idea what made the wires melt like that tho.
afnan
19
Jul 9, 2021 09:28 AM
deving916
Nov 19, 2013 12:43 PM
John Anderson
13
Mar 30, 2012 06:44 PM
RyanStevenPhillips
Lighting
Oct 13, 2008 03:10 PM
rice4life
Jun 14, 2002 07:34 AM
